  • Visaton K50FL-16 2" Waterproof Miniature Driver with Plastic Diaphragm 16 Ohm
Visaton
Part #292-720
Visaton
Part #292-720
Model: K50FL-16
The Visaton K50FL-16 is a compact 2" miniature speaker that delivers excellent speech reproduction. Specifically designed to fit and function perfectly in confined spaces, this speaker is your ideal solution for signal output in machines and equipment where size matters.
  • Rated power of 1W and maximum power of 2W
  • Frequency response ranging from 150–20000 Hz
  • Resilience in various temperature conditions, from -40 °C to +70 °C
  • Compact and efficient design, ideal for equipment where space is limited
  • Provides excellent speech reproduction
  • IP65 when built into a sealed enclosure
Your Price: $5.98
MSRP: $6.36
Save $0.38 (6%)
Quantity:Qty: 1-9 $5.98/ea
Quantity:Qty: 10+$5.50/ea
Out of Stock
The Visaton K50FL-16 is a 2" miniature speaker that brings together compact design and sound clarity. Crafted with a plastic diaphragm, this speaker is adept at speech reproduction, making it the ideal choice for signal output in machines and equipment where space is at a premium. Its compact design belies its impressive technical specifications. The K50FL-16 offers a frequency response ranging from 150–20000 Hz, catering to a wide array of sound needs. With a rated power of 1W and a maximum power of 2W, it promises to deliver dependable performance. The speaker is designed to weather diverse environments. Capable of withstanding temperature extremes from -40 °C to +70 °C, it is not only resilient but also features an IP65 protective system when incorporated into a sealed enclosure. This ensures the speaker is protected from dust and low-pressure water jets from any direction. For situations that require compact yet effective sound solutions, the Visaton K50FL-16 serves as an excellent choice. Its ability to provide good speech reproduction and durability in varied conditions makes it a reliable choice for many applications.
BrandVisaton
ModelK50FL-16
Part Number292-720
Nominal Diameter2"
Power Handling (RMS)1 Watts
Power Handling (MAX)2 Watts
Impedance16Ω
Frequency Response150 to 20,000Hz
Sensitivity80dB 2.83V/1m
Voice Coil Diameter0.51"
Resonant Frequency (Fs)340Hz
Overall Outside Diameter1.97"
Baffle Cutout Diameter1.81"
Depth0.31"
MONSTER DEAL
OF THE WEEK
$129.49 EACH
SAVE $14
Dayton Audio HTA20 20 Watt Integrated Stereo Hybrid Tube Amplifier With USB-DAC and Bluetooth 5.0
