  • Visaton HTH 8.7 Professional Constant Directivity Horn 8 Ohm
Visaton
Part #292-649
Visaton
Part #292-649
Model: HTH 8.7
With excellent response from 1,200 Hz to 16,000 Hz up to 45° off axis, Visaton's HTH 8.7 8 ohm constant directivity horn tweeter is an ideal tweeter for use in stage monitors and small PA speakers, or even in high efficiency home speaker designs.
  • Wide horizontal and vertical dispersion creates room filling sound
  • Smooth roll off on both ends of the useable bandwidth keeps crossover design simple
  • Impressive 200 watt power handling with recommended crossover of 5,000 Hz @ 12 dB/octave
  • 106 dB at 1W/1m efficiency delivers a lot of output with little power input
Your Price: $69.74
MSRP: $90.99
Save $21.25 (23%)
Quantity:Qty: 1-9 $69.74/ea
Quantity:Qty: 10-24 $67.66/ea
Quantity:Qty: 25+$64.76/ea
Order in the next 18 hr 27 min to ship today. Details
Only 2 In Stock
More due any day
Visaton's HTH 8.7 8 ohm professional CD (constant directivity) horn tweeter is designed to accurately reproduce high frequencies above 3,000 Hz. The square shaped horn system is made of rugged black plastic and equipped with a 1" voice-coil for high power handling. Thanks to a smooth roll off on both the high and low end of its useable bandwidth crossover design for this tweeter will be simple and predictable. This horn is an ideal high range component for compact 2- and 3-way speakers used as stage monitors or small PA for instruments and vocals. With its smooth response and wide dispersion, the HTH 8.7 is also an excellent choice for use in high efficiency home speaker designs.
Specifications: • Power handling: 200 watts RMS (with 12 dB/octave 5,000 Hz crossover), 300 watts peak • VCdia: 1" • Fs: 2,152 Hz • Le: 0.36 mH • Impedance: 8 ohms • Re: 7.5 ohms • Frequency response: 1,200 -16,000 Hz • SPL: 106 dB 1W/1m • Dimensions: 6.1" H x 7.67" W x 4.92 D, Cutout diameter: 4.8" H x 6.45" W • Net weight: 2 lb.
BrandVisaton
ModelHTH 8.7
Part Number292-649
Weight2.4
Diaphragm MaterialPhenolic
Power Handling (RMS)200 Watts
