  • Visaton FRS7-4 2.5" Full-Range Speaker 4 Ohm
Visaton
Part #292-528
Visaton
Part #292-528
Model: FRS7 - 4
Designed to fit the bill for a wide range of outdoor audio applications, Visaton's 2011 FRS7 2-1/2" full-range driver features a water resistant cone. 4 Ohm impedance.
  • Useful for background music and constant voltage PA systems
  • 2.5", 4-ohm full-range speaker with linear response from 200 Hz to 20 kHz
  • Paper cone with foam surround
  • Water-resistant design
Your Price: $12.96
MSRP: $16.99
Save $4.03 (24%)
Quantity:Qty: 1-9 $12.96/ea
Quantity:Qty: 10-24 $12.39/ea
Quantity:Qty: 25+$12.04/ea
192In Stock
Visaton's 2011 FRS7 2.5", 4 ohm full-range driver features a water resistant cone and is suitable as a midrange driver in three-way speakers, wide-band use in background and constant-voltage industrial PA speaker systems (transformer not included). The high output design is also great for use in applications where size restrictions exist. An optional grill is available in the Related Items section to provide additional protection.
BrandVisaton
ModelFRS7 - 4
Part Number292-528
Weight0.454
Nominal Diameter2-1/2"
Power Handling (RMS)8 Watts
Power Handling (MAX)15 Watts
Frequency Response200 to 20,000Hz
Sensitivity88dB 2.83V/1m
Voice Coil Diameter0.5"
Resonant Frequency (Fs)250Hz
DC Resistance (Re)3.6Ω
Mechanical Q (Qms)3.21
Electromagnetic Q (Qes)1.96
Total Q (Qts)1.22
Compliance Equivalent Volume (Vas)0.01ft³
Maximum Linear Excursion (Xmax)0.75mm
Cone MaterialTreated Paper
Overall Outside Diameter2.62"
Baffle Cutout Diameter2.4"
Depth1.18"
Sealed Volume0.02ft³
Sealed F3224.5Hz
Vented Volume0.02ft³
Vented F3175.4Hz
