  • Visaton BF32S 1.3" Full-Range Speaker 8 ohm
1 Question, 1 Answer or
Visaton
Part #292-654
Visaton
Part #292-654
Model: BF32S
The Visaton BF32S is a full-range speaker with a wide and balanced frequency response. Suitable for applications where slim construction and accurate reproduction of music and speech are needed. The square mounting flange make utilizing this driver in a line array, very easy..
  • Ideal for line arrays and compact speaker installations
  • Great frequency response from 200 to 16,000 Hz
  • Self-shielded neodymium motor
  • Extremely uniform off axis frequency response
Your Price: $10.71
MSRP: $13.99
Save $3.28 (23%)
Quantity:Qty: 1-9 $10.71/ea
Quantity:Qty: 10-24 $10.39/ea
Quantity:Qty: 25+$9.94/ea
Out of Stock
Visaton designed the BF32S 1.3" full-range speaker with a wide and balanced frequency response, and very good low range reproduction. A powerful neodymium motor helps to achieve a rather high sensitivity for a driver this size.
This driver is perfect for micro-thin line arrays, modern multimedia use in flat panel TVs, informational use in point-of-purchase displays, and other audio applications where conventional speakers are simply too large.
BrandVisaton
ModelBF32S
Part Number292-654
Nominal Diameter1-1/2"
Power Handling (RMS)2 Watts
Power Handling (MAX)5 Watts
Frequency Response150 to 20,000Hz
Sensitivity78dB 2.83V/1m
Voice Coil Diameter0.79"
Resonant Frequency (Fs)220Hz
Overall Outside Diameter1.26"
Baffle Cutout Diameter1.18"
Depth0.43"
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
