  • Visaton B 200 8" Full-Range Driver 6 Ohm
2 Questions, 4 Answers or
Visaton
Part #292-664
Visaton
Part #292-664
Model: B200
Visaton's B 200 8" full-range high fidelity driver produces smooth response all the way up to 18,000 Hz thanks to an extremely light-weight cone and voice coil assembly. Perfect for sealed and open baffle designs, this driver is optimized to deliver natural response with very low distortion.
  • Light-weight paper cone and fabric surround produces superb damping
  • 25 mm aluminum voice coil keeps mass low for fantastic high frequencies
  • Cast aluminum frame allows extensive venting and minimal resonances
  • Ideal for open baffle and sealed designs, but also suitable for horn loaded systems
  • For a quote on a large qty order, please press "Request Large Qty Quote" -
Your Price: $211.71
MSRP: $275.99
Save $64.28 (23%)
Quantity:Qty: 1-9 $211.71/ea
Quantity:Qty: 10-24 $205.39/ea
Quantity:Qty: 25+$196.59/ea
Order in the next 1 hr 35 min to ship today. Details
Only 4 In Stock
The B 200 8" full-range high fidelity driver from Visaton is a unique driver with high sensitivity and extremely well behaved frequency response all the way up to 18,000 Hz. This is achieved by using a very light-weight paper cone and fabric surround with excellent damping for minimal resonances. The 25 mm aluminum wire voice coil makes optimum use of the magnetic field in the air gap. The Kapton voice coil former is vented to minimize compression in high output situations. The sturdy aluminum diecast basket is not only optically appealing but, thanks to its rear-venting openings, ensures that physical losses are minimized. All of this allows the B 200 to deliver extremely low distortion and an incredibly life-like sound. Suitable for conventional sealed and vented enclosures this driver is also an excellent choice for use in more exotic alternatives like horn loaded or open baffle systems to create amazing results.
BrandVisaton
ModelB200
Part Number292-664
Weight5.4
Nominal Diameter8"
Bolt Circle Diameter8.27
Power Handling (RMS)40 Watts
Power Handling (MAX)70 Watts
Frequency Response40 to 20,000Hz
Sensitivity96dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)40Hz
DC Resistance (Re)
Voice Coil Inductance (Le)0.5mH
Mechanical Q (Qms)8.39
Electromagnetic Q (Qes)0.83
Total Q (Qts)0.76
Compliance Equivalent Volume (Vas)3.6ft³
Mechanical Compliance of Suspension (Cms)1.63mm/N
BL Product (BL)3.9T·m
Diaphragm Mass Inc. Airload (Mms)9.7g
Maximum Linear Excursion (Xmax)3.5mm
Surface Area of Cone (Sd)214cm²
Cone MaterialPaper
Surround MaterialCloth
Overall Outside Diameter8.74"
Baffle Cutout Diameter7.45"
Depth3.62"
# Mounting Holes6
Sealed Volume0.75ft³
Sealed F368.9Hz
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
