VViViD XPO Wood Grain Textured Dark Wood Premium Film Vinyl Wrap 49" x 3 ft.This vinyl film wrap gives your projects a textured or a paint-like finish. Just peel off the backing to apply the film. Heat it, stretch it, form it, and trim off the excess. When covering larger objects, a second person is recommended to keep your work from moving while heating and stretching the vinyl. You can use bar a clamp (365-113) for small to medium size jobs. No glue, no paint and no mess to clean-up. Cover your whole project or just use the eye-catching vinyl to highlight certain areas.
Give your old and faded components a brand new look. Wow the crowd, by trimming your guitar and drums with eye catching shapes and stripes. Make your Bluetooth speaker match the colors of your room's decor. Wrap the interior pieces or the hood of your car to give it that custom look. There are so many colors and textures of VViViD XPO premium vinyl film wraps to choose from. Why stop with just one? The possibilities are endless!
Air Release Technology: The primary function of this technology is to remove air from underneath the vinyl film before securing it in place. This gives you a bubble free paint-like finish. The vinyl's air release pattern also has a secondary purpose called adhesive fusing. This creates a suction cup effect adding to the overall strength and stability to the film.
VViViD has come out with a new adhesive backing called ViVViD8. This new adhesive gives you more flexibility, extreme repositioning, and a stable installation with almost no chance of peeling or curling. Now you can reposition the film with no stretch marks, or any other type of imperfections caused by aggressive adhesion. With this advantage you get up to four times faster install times and if it gets folded or creased, the glue will not stick to itself.
Specifications: • Thickness: 4.5 mils • Size: 49" x 3 ft.
