  • Timpano Audio TPT-ST2-Black 4" Super Tweeter Pair
Timpano Audio
Part #294-3083
Timpano Audio
Part #294-3083
Model: TPT-ST2-Black
Timpano Audio's TPT-ST2 horn loaded super tweeter pair can provide high output in systems where space is at a premium. The aluminum diaphragm and horn loaded design delivers dynamic and detailed response even at high output levels.
  • Response up to 23,000 Hz for incredible accuracy and detail
  • 105 dB sensitivity to deliver high output even with lower power designs
  • Aluminum diaphragm produces accurate response and high efficiency
  • Included high pass crossover protects tweeter from damaging low frequencies
Your Price: $22.95
MSRP: $28.69
Save $5.74 (20%)
When space is at a premium, but you need high output, the TPT-ST2 super tweeter pair from Timpano Audio is ideal. The aluminum diaphragm and 1" voice coil can handle up to 60 watts RMS. That, combined with 105 dB efficiency, gives the TPT-ST2 incredible long term output capability for its size. With a frequency response of 2,000 to 23,000 Hz, this horn loaded bullet tweeter will provide an extremely detailed and dynamic sound. All of this makes the TPT-ST2 super tweeter pair a fantastic value.
• Power handling: 100 watts RMS/300 watts max (each), 200 watts RMS/600 watts max (per pair)
• VCdia: 1"
• Impedance: 4 ohms
• Frequency response: 2,000-23,000 Hz
• SPL: 105 dB 1W/1m
• Dimensions: 3.875" Dia x 1.75" D.
• Baffle cutout diameter (front mount): 2.75"
• Weight: 2.15 lbs/pair.
Note: The TPT-ST2 is sold in pairs.
BrandTimpano Audio
ModelTPT-ST2-Black
Part Number294-3083
UPC611056238677
Unit of MeasurePairs
Weight2.3
Diaphragm MaterialAluminum
Power Handling (RMS)60 Watts
