  • Timpano Audio TPT-DH2000 2" Exit Aluminum Horn with Titanium Driver
Timpano Audio
Part #294-3081
Timpano Audio
Part #294-3081
Model: TPT-DH2000
Timpano Audio's TPT-DH2000 horn loaded tweeter delivers accurate high frequency response even when pushed to extreme output levels. The rugged cast aluminum horn and compression driver with titanium diaphragm are designed for high efficiency and smooth response.
  • 2" titanium diaphragm for detailed response and high power handling
  • Shallow design to fit in almost any system, even car doors
  • 109 dB sensitivity for high output even in moderately powered systems
  • Cast aluminum horn can withstand the use and abuse of pro or car audio environment
Your Price: $69.95
MSRP: $87.44
Save $17.49 (20%)
The TPT-DH2000 horn loaded tweeter from Timpano Audio produces a wide frequency response, from 1,000 to 20,000 Hz, to cover everything from the vocal range up to the highest frequencies. The 2" titanium diaphragm minimizes resonances for low distortion and natural but accurate response. The solid cast aluminum horn controls dispersion to reduce unwanted reflection while maximizing efficiency. At only 5.5" deep, the TPT-DH2000 is easy to install anywhere, even car doors. In addition, the small diameter of the compression driver allows simple installation for the front. With high power handling and efficiency, this tweeter is ideal for systems capable of incredibly high output levels.
Specifications: • Power handling: 100 watts RMS/200 watts peak • VCdia: 2" • Impedance: 8 ohms • Frequency response: 1,000-20,000 Hz • SPL: 109 dB 1W/1m • Dimensions: 6.125" H x 6.1215" W x 5.5" D. • Baffle cutout diameter (front mount): 5.5" • Weight: 7.2 lbs.
BrandTimpano Audio
ModelTPT-DH2000
Part Number294-3081
UPC611056238691
Weight7.75
Diaphragm MaterialTitanium
Power Handling (RMS)100 Watts
