  • Timpano Audio TPT-DH175 SLIM 1" Exit Plastic Horn with Phenolic Compression Driver
Timpano Audio
Part #294-3354
Timpano Audio
Part #294-3354
Model: TPTDH175 SLIM
Timpano Audio's shallow mount TPT-DH175 SLIM phenolic horn loaded tweeter will deliver smooth response with enough output to fill the high frequency needs of high SPL sound systems. With just over 3-1/2" mounting depth, this tweeter is easy to install in locations such as car doors and trunk lids..
  • Lightweight and 3.6" mounting depth for easy installation in car doors and trunk lids
  • Phenolic diaphragm produces natural response with minimal resonance
  • 108 dB sensitivity for high output even with moderate power
  • 45° x 45° dispersion pattern to fill any space with sound
Your Price: $19.95
MSRP: $24.94
Save $4.99 (20%)
Only 3 In Stock
The TPT-DH175 SLIM horn loaded tweeter from Timpano Audio uses a naturally damped 1" phenolic diaphragm for natural response and detailed high frequencies. At only 4.5" x 4.5" and 3.6" deep, this tweeter can easily be installed in tight spaces like car doors and trunk lids. The 45° x 45° dispersion patter gives the TPT-DH175 SLIM the ability to evenly fill open spaces. At 108 dB efficiency and with 75 watt RMS power handling this tweeter hat the output capability to keep up with high SPL systems.
Specifications: • Power handling: 75 watts RMS (crossover frequency 2,500 kHz, 12 dB/octave), 150 watts max • Impedance: 8 ohms • Useable range: 1,300-19,000 Hz • Dispersion: 45° H x 45° V • Recommended crossover: 2,500 Hz • SPL: 108 dB 2.83V/1m • Mfg. #: TPT-DH175 SLIM • Dimensions: 4.5" H x 4.5" W x 4.2" D • Cutout dimensions: 3.38" diameter (with notch for terminals).
BrandTimpano Audio
ModelTPTDH175 SLIM
Part Number294-3354
UPC611056239155
Weight2
Diaphragm MaterialPhenolic
Power Handling (RMS)75 Watts
