  • Timpano Audio TPT-DH150 1" Phenolic Horn Loaded Tweeter 8 Ohms
Timpano Audio
Part #294-3356
Timpano Audio
Part #294-3356
Model: TPT-DH150
Timpano Audio's high output TPT-DH150 compact horn tweeter has a mounting depth of only 2-3/4" for easy installation in difficult spots like car doors or trunk lids. This tweeter uses a 1" phenolic diaphragm to produce detailed and natural response.
  • 104 dB sensitivity for high output even with moderate power
  • Only 2-3/4" for easy installation in car doors and trunk lids
  • Compact horn design for controlled dispersion and high efficiency
  • Naturally damped phenolic diaphragm produces smooth natural response
Your Price: $16.95
MSRP: $21.19
Save $4.24 (20%)
Expected back in stock any day
Alert Me When Available
Capable of high output, the TPT-DH150 horn loaded tweeter from Timpano Audio will add detailed high frequencies to any high SPL sound system. At only 4" diameter and 2-3/4" deep this tweeter will fit into your design even when space is at a premium. With a 1" phenolic diaphragm you can expect natural and dynamic response from the TPT-DH150. The 104 dB sensitivity and 75 watt RMS power handling ensure that the tweeter can deliver extremely high output when you need it.
Specifications: • Power handling: 75 watts RMS (crossover frequency 5,000 kHz, 12 dB/octave), 150 watts max • Impedance: 8 ohms • Useable range: 1,500-18,000 Hz • Recommended crossover: 5,000 Hz • SPL: 104 dB 2.83V/1m • Dimensions: 4" Dia x 2.75" D • Cutout dimensions: 3" Dia.
BrandTimpano Audio
ModelTPT-DH150
Part Number294-3356
UPC611056238653
Weight1.05
Diaphragm MaterialPhenolic
Power Handling (RMS)75 Watts
