Timpano Audio TPT-D3000 2" Titanium Compression Horn Driver 4-Bolt
- 3" titanium diaphragm and voice coil to withstand peaks up to 200 watts
- Massive ferrite motor for high efficiency and excellent heat dissipation
- Accepts crossovers as low as 1,500 Hz for easy transition to midrange drivers
- The 2" exit and 4-bolt mount make this driver compatible with many popular horns
Only 3 In Stock
We'll send you an email when Timpano Audio TPT-D3000 2" Titanium Compression Horn Driver 4-Bolt is back in stock or available for preorder.
