  • Tang Band W8-2314 8" Coaxial Full-Range Woofer
Tang Band
Part #264-9004
Tang Band
Part #264-9004
Model: W8-2314
Tang Band's W8-2314 is an incredible 8" bamboo fiber woofer paired with a 1" hi-res tweeter in its center. The tweeter features an aluminum and magnesium blended dome that plays up to 40,000 Hz! This coaxial will produce an extremely smooth response on and off-axis while avoiding the phase and lobing issues associated with standard 2-way designs.
  • Incredible full-range response from 38 - 40,000 Hz
  • Underhung neodymium motor design offers extremely low distortion
  • Utilizes Tang Band's famous bamboo fiber cone
  • Aluminum/Magnesium tweeter dome offers extremely high frequency extension
  • This item available through special order only. Minimum order quantity is 50 pieces
Your Price: $319.98
MSRP: $415.99
Save $96.01 (23%)
Quantity:Qty: 50+$319.98/ea
Out of Stock
Ships in 90-120 days, minimum order quantity 50 pcs.
Alert Me When Available
The Tang Band W8-2314 is a full-range coaxial loudspeaker providing high quality sound in a very compact format. The woofer features an 8" bamboo fiber cone that offers a nice balance between rigidity, low mass and damping. An underhung neodymium motor design allows this driver to remain extremely linear and relatively distortion-free throughout its intended bandwidth.
The 1" tweeter features an aluminum and magnesium blended dome, as well as a rear chamber that allows it to play from 800 to 40,000 Hz! In addition, the optimized tweeter placement and flaring reduces the phase issues with the woofer that is commonplace with many of the BIG brand coaxial drivers.
BrandTang Band
ModelW8-2314
Part Number264-9004
UPC848864053578
Weight6.8
Nominal Diameter8"
Bolt Circle Diameter8.27
Power Handling (RMS)50 Watts
Power Handling (MAX)100 Watts
Frequency Response38 to 40,000Hz
Sensitivity90dB 2.83V/1m
Voice Coil Diameter1.75"
Resonant Frequency (Fs)38Hz
DC Resistance (Re)3.6Ω
Voice Coil Inductance (Le)0.072mH
Mechanical Q (Qms)2.14
Electromagnetic Q (Qes)0.37
Total Q (Qts)0.31
Compliance Equivalent Volume (Vas)1.8ft³
Mechanical Compliance of Suspension (Cms)0.7459mm/N
BL Product (BL)7.4T·m
Diaphragm Mass Inc. Airload (Mms)23.14g
Cone MaterialBamboo Fiber / Paper
Magnet MaterialNeodymium
Overall Outside Diameter8.8"
Baffle Cutout Diameter7.19"
Depth3.7"
# Mounting Holes6
Sealed Volume0.35ft³
Sealed F397.1Hz
Vented Volume1ft³
Vented F340.7Hz
