  • Tang Band W6-2313 6-1/2" Coaxial Full-Range Woofer
Tang Band
Part #264-9002
Tang Band
Part #264-9002
Model: W6-2313
Tang Band's W6-2313 is an incredible 6.5" bamboo fiber woofer paired with a 1" hi-res tweeter in its center. The tweeter features an aluminum and magnesium blended dome that plays up to 40,000 Hz! This coaxial will produce an extremely smooth response on and off-axis while avoiding the phase and lobing issues associated with standard 2-way designs.
  • Incredible full-range response from 50-40,000 Hz
  • Underhung neodymium motor design offers extremely low distortion
  • Utilizes Tang Band's famous bamboo fiber cone
  • Aluminum/Magnesium tweeter dome offers extremely high frequency extension
Your Price: $244.98
MSRP: $318.99
Save $74.01 (23%)
Quantity:Qty: 1-3 $244.98/ea
Quantity:Qty: 4+$239.98/ea
Order in the next 1 hr 41 min to ship today. Details
11In Stock
The Tang Band W6-2313 is a full-range coaxial loudspeaker providing high quality sound in a very compact format. The woofer features a 6" bamboo fiber cone that offers a nice balance between rigidity, low mass and damping. An underhung neodymium motor design allows this driver to remain extremely linear and relatively distortion-free throughout its intended bandwidth.
The 1" tweeter features an aluminum and magnesium blended dome, as well as a rear chamber that allows it to play from 800 to 40,000 Hz! In addition, the optimized tweeter placement and flaring reduces the phase issues with the woofer that is commonplace with many of the BIG brand coaxial drivers.
BrandTang Band
ModelW6-2313
Part Number264-9002
UPC848864053561
Weight5.1
Nominal Diameter6-1/2"
Bolt Circle Diameter6.38
Power Handling (RMS)45 Watts
Power Handling (MAX)90 Watts
Frequency Response50 to 40,000Hz
Sensitivity87dB 2.83V/1m
Voice Coil Diameter1.75"
Resonant Frequency (Fs)50Hz
DC Resistance (Re)3.6Ω
Mechanical Q (Qms)6.02
Electromagnetic Q (Qes)0.41
Total Q (Qts)0.38
Compliance Equivalent Volume (Vas)0.38ft³
Mechanical Compliance of Suspension (Cms)0.38mm/N
BL Product (BL)8.41T·m
Diaphragm Mass Inc. Airload (Mms)24.95g
Surface Area of Cone (Sd)25.67cm²
Cone MaterialBamboo Fiber / Paper
Magnet MaterialNeodymium
Overall Outside Diameter7.06"
Baffle Cutout Diameter5.82"
Depth3.16"
# Mounting Holes6
Sealed Volume0.18ft³
Sealed F3105Hz
Vented Volume0.4ft³
Vented F348.7Hz
