  • Tang Band W4-2074 Compact 4" Bass Shaker Tactile Transducer
4 Questions, 6 Answers or
Tang Band
Part #264-972
Tang Band
Part #264-972
Model: W4-2074
Add more realistic tactile feedback to movie and gaming system with the Tang Band W4-2074 compact bass shaker. At under 5" diameter, this powerful transducer is perfect for use in tight spaces. The W4-2074 can produce powerful vibration, which is ideal for enhancing the feeling of low frequencies.
  • Compact size for installation into tight spaces
  • Give movies and gaming system realistic tactile feedback
  • Attached 20" leads makes hook up easy in tight spaces
  • 28 Watts RMS is ideal for use with smaller amplifiers
Your Price: $89.98
MSRP: $127.99
Save $38.01 (30%)
Quantity:Qty: 1-3 $89.98/ea
Quantity:Qty: 4-9 $85.28/ea
Quantity:Qty: 10+$83.28/ea
With the Tang Band W4-2074 4" bass shaker you can add realism and actual low frequency impact to home theaters and gaming systems. The compact size makes this tactile transducer ideal for use in areas where space is at a minimum. However, don't let the small size fool you, the W4-2074 has the power to produce realistic vibrations that will shake you from head to toe when needed. The attached 20" leads make hookup easy even when installed in hard to reach spaces.
Don’t just hear your games and movies, with Tang Band's W4-2074 you can actually feel the action and impact!
BrandTang Band
ModelW4-2074
Part Number264-972
UPC848864064024
Weight1.5
ApplicationLow Frequency Bass Shaker
Power Handling (RMS)28 Watts
MONSTER DEAL
OF THE WEEK
$23.98 EACH
SAVE 20%
Lepai LP‑2020BT Bluetooth Hi-Fi Audio Mini Class D Stereo Amplifier FM Media with Power Supply
