  • Tang Band W3-881SJF 3" Full Range Speaker
Tang Band
Part #264-911
Tang Band
Part #264-911
Model: W3-881SJF
The Tang Band W3-881SJF is characterized by extended, very smooth frequency response. Its powerful ceramic magnet system and underhung voice coil contribute to extremely low distortion.
Your Price: $46.98
MSRP: $60.99
Save $14.01 (23%)
Quantity:Qty: 1-3 $46.98/ea
Quantity:Qty: 4+$44.63/ea
Order in the next 0 hr 40 min to ship today. Details
399In Stock
The Tang Band W3-881SJF is an exceptional 3" transducer that features a PPM cone, Santoprene surround, cast aluminum frame, and powerful underhung-design ceramic motor. Its copper-clad aluminum wire voice coil is wound on a polyimide former, the combination of which provides high power handling and extended HF response. The W3-881SJF is an ideal choice for single driver full-range applications, as well as deployment in multiple speaker configurations such as line arrays.
BrandTang Band
ModelW3-881SJF
Part Number264-911
UPC844632092794
Weight1.5
Nominal Diameter3"
Power Handling (RMS)15 Watts
Power Handling (MAX)30 Watts
Frequency Response100 to 20,000Hz
Sensitivity88dB 2.83V/1m
Voice Coil Diameter0.8"
Resonant Frequency (Fs)100Hz
DC Resistance (Re)6.6Ω
Voice Coil Inductance (Le)0.8mH
Mechanical Q (Qms)6.44
Electromagnetic Q (Qes)0.41
Total Q (Qts)0.39
Compliance Equivalent Volume (Vas)0.07ft³
Mechanical Compliance of Suspension (Cms)1.32mm/N
BL Product (BL)4.47T·m
Diaphragm Mass Inc. Airload (Mms)2g
Maximum Linear Excursion (Xmax)0.5mm
Surface Area of Cone (Sd)32cm²
Cone MaterialPoly
Surround MaterialSantoprene®
Voice Coil Wire MaterialCCA
Overall Outside Diameter3.66"
Baffle Cutout Diameter2.95"
Depth2.32"
Sealed Volume0.05ft³
Sealed F3209.3Hz
Vented Volume0.05ft³
Vented F3114.6Hz
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
