  • Tang Band W3-881SJ 3" Cast Frame Neodymium Driver
Tang Band
Part #264-812
Tang Band
Part #264-812
Model: W3-881SJ
Tang Band's 3" full range W3-881SJ offers high quality sound from 100 to 20,000 Hz. It features a powerful neodymium motor, cast aluminum basket, and a PPM cdone with Santoprene surround.
Your Price: $46.40
MSRP: $69.99
Save $23.59 (34%)
Quantity:Qty: 1-3 $46.40/ea
Quantity:Qty: 4-9 $44.08/ea
Quantity:Qty: 10+$41.76/ea
Order in the next 4 hr 13 min to ship today. Details
250In Stock
This is an exceptional 3" driver featuring a PPM cone, rubber surround, cast aluminum frame, and self-shielded underhung neodymium motor. The small magnet size reduces harmful reflections behind the cone and makes installation in small enclosures much easier. This is an exceptional little driver, excelling at midrange and full-range applications.
BrandTang Band
ModelW3-881SJ
Part Number264-812
UPC844632019432
Weight0.5
Nominal Diameter3"
Power Handling (RMS)15 Watts
Power Handling (MAX)30 Watts
Frequency Response100 to 20,000Hz
Sensitivity86dB 2.83V/1m
Voice Coil Diameter0.75"
Resonant Frequency (Fs)100Hz
DC Resistance (Re)6.6Ω
Mechanical Q (Qms)3.07
Electromagnetic Q (Qes)0.8
Total Q (Qts)0.63
Compliance Equivalent Volume (Vas)0.078ft³
Mechanical Compliance of Suspension (Cms)1.31mm/N
BL Product (BL)2.9T·m
Diaphragm Mass Inc. Airload (Mms)1.6g
Maximum Linear Excursion (Xmax)0.5mm
Surface Area of Cone (Sd)32cm²
Cone MaterialPoly
Surround MaterialSantoprene®
Magnet MaterialNeodymium
Overall Outside Diameter3.66"
Baffle Cutout Diameter2.95"
Depth1.77"
Sealed Volume0.08ft³
Sealed F3128.8Hz
Vented Volume0.08ft³
Vented F392.5Hz
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
