  • Tang Band W3-1878 3" Full-Range Driver
Tang Band
Part #264-902
Tang Band
Part #264-902
Model: W3-1878
The Tang Band W3-1878 full-range driver features an underhung neodymium motor design that provides extended, linear response while reducing 2nd and 3rd harmonic distortion.
  • Full-range capability
  • Underhung voice coil
  • Neodymium magnet structure
  • Extremely low harmonic distortion
  • Bamboo fiber paper cone
  • Durable foam rubber surround
  • Unique aluminum phase plug
Your Price: $134.98
MSRP: $194.99
Save $60.01 (31%)
Quantity:Qty: 1-3 $134.98/ea
Quantity:Qty: 4+$128.23/ea
99In Stock
The Tang Band W3-1878 full-range driver features an underhung neodymium motor design that provides extended, linear response while reducing 2nd and 3rd harmonic distortion. The bamboo/paper cone is lightweight yet appropriately rigid and is terminated with a durable foam rubber half roll surround. A unique aluminum phase plug improves dispersion at the speaker's higher frequencies.
BrandTang Band
ModelW3-1878
Part Number264-902
UPC844632088384
Weight1.8
Nominal Diameter3"
Power Handling (RMS)12 Watts
Power Handling (MAX)25 Watts
Frequency Response75 to 20,000Hz
Sensitivity88dB 2.83V/1m
Voice Coil Diameter0.8"
Resonant Frequency (Fs)75Hz
DC Resistance (Re)6.5Ω
Mechanical Q (Qms)1.67
Electromagnetic Q (Qes)0.34
Total Q (Qts)0.28
Compliance Equivalent Volume (Vas)0.11ft³
Mechanical Compliance of Suspension (Cms)2.12mm/N
BL Product (BL)4.3T·m
Diaphragm Mass Inc. Airload (Mms)2g
Maximum Linear Excursion (Xmax)4.2mm
Surface Area of Cone (Sd)32cm²
Cone MaterialBamboo Fiber / Paper
Magnet MaterialNeodymium
Overall Outside Diameter3.66"
Baffle Cutout Diameter2.97"
Depth2.54"
Vented Volume0.075ft³
Vented F375.1Hz
