  • Tang Band W2-1803S 2" Neodymium Poly Full-Range Driver
Tang Band
Part #264-885
Tang Band
Part #264-885
Model: W2-1803S
Miniature full-range transducer. Polypropylene diaphragm with Santoprene rubber surround. 9/16" aluminum voice coil and high-energy, lightweight neodymium magnet structure.
  • This item available through special order only. Minimum order quantity is 50 pieces
Your Price: $26.98
MSRP: $35.99
Save $9.01 (25%)
Quantity:Qty: 50+$26.98/ea
Out of Stock
Ships in 90-120 days, minimum order quantity 300 pcs.
Alert Me When Available
Miniature full-range transducer. Polypropylene diaphragm with Santoprene rubber surround. 9/16" aluminum voice coil and high-energy, lightweight neodymium magnet structure. Works well in small computer audio applications, or wherever tiny hi-fidelity drivers are required.
BrandTang Band
ModelW2-1803S
Part Number264-885
UPC844632078958
Weight0.15
Nominal Diameter2"
Power Handling (RMS)3 Watts
Power Handling (MAX)6 Watts
Frequency Response155 to 20,000Hz
Sensitivity82dB 2.83V/1m
Voice Coil Diameter0.5625"
Resonant Frequency (Fs)155Hz
DC Resistance (Re)5.6Ω
Voice Coil Inductance (Le)0.08mH
Mechanical Q (Qms)2.84
Electromagnetic Q (Qes)0.94
Total Q (Qts)0.7
Compliance Equivalent Volume (Vas)0.01ft³
Mechanical Compliance of Suspension (Cms)1.37mm/N
BL Product (BL)2.12T·m
Diaphragm Mass Inc. Airload (Mms)0.77g
Maximum Linear Excursion (Xmax)0.7mm
Surface Area of Cone (Sd)13cm²
Cone MaterialPoly
Surround MaterialSantoprene®
Magnet MaterialNeodymium
Overall Outside Diameter2.24"
Baffle Cutout Diameter2.05"
Depth1.25"
Sealed Volume0.02ft³
Sealed F3178.1Hz
Vented Volume0.02ft³
Vented F3119.6Hz
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
