  • Tang Band W1-1942S 1" Full-Range Neodymium Driver
Tang Band
Part #264-924
Tang Band
Part #264-924
Model: W1-1942S
Modern speaker designs and applications call for drivers that are exceptionally small. Traditionally, the sacrifice when using small drivers is performance. Tang Band's 46 mm W1-1942S full range driver plays from 120 Hz all the way up to 20,000 Hz without losing fidelity!
  • Amazing extended range response from 120 to 20,000 Hz
  • Perfect for line-arrays and modern speaker designs
  • Super low 0.046 mH inductance and ferrofluid cooled
  • Low 0.24 Qts driver for superior high fidelity performance
  • Santoprene surround with mineral filled poly cone and press-fit frame design
  • This item available through special order only. Minimum order quantity is 50 pieces
Your Price: $51.95
MSRP: $71.99
Save $20.04 (28%)
Out of Stock
Ships in 90-120 days, minimum order quantity 300 pcs.
Alert Me When Available
Tang Band's W1-1942S micro full-range driver features amazing performance that belies its diminutive 46 mm diameter (just over 1-3/4") size. The patented design employs a unique polypropylene cone, with flower petal embossments, that's mated to a neodymium motor for maximum BL product in the voice coil gap. A free air resonance of 120 Hz allows you to pair these nearly any woofer or subwoofer up to 9 feet away without localization and beaming effects (poor off-axis response).
Additionally, you can use these drivers in multiples for an awesome line-array speaker that requires a miniscule footprint. Great for use in designing micro LCR (left, center, right) speakers for modern flat panel HDTVs, or even computer desk and laptop speakers. The high-fidelity nature of these drivers is exemplified by their low Qts specification (quite rare in drivers this size), while the ultra-low inductance allows these to play relatively flat frequency response up 20,000 Hz! Ferrofluid cooling protects and cools the voice coil, while the mineral-filled polypropylene cone combines with the Santoprene surround for use in harsh environments. Press-fit frame design minimizes center-to-center distance.
Note: Higher power handling can be achieved by using a 150 Hz 2nd-order high-pass filter, or by using multiple drivers together.
BrandTang Band
ModelW1-1942S
Part Number264-924
UPC844632099427
Weight0.2
Nominal Diameter1"
Power Handling (RMS)4 Watts
Power Handling (MAX)8 Watts
Frequency Response120 to 20,000Hz
Sensitivity82dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)120Hz
DC Resistance (Re)3.5Ω
Voice Coil Inductance (Le)0.046mH
Mechanical Q (Qms)1.79
Electromagnetic Q (Qes)0.27
Total Q (Qts)0.24
Compliance Equivalent Volume (Vas)0.005ft³
Mechanical Compliance of Suspension (Cms)1.37mm/N
BL Product (BL)3.49T·m
Maximum Linear Excursion (Xmax)1.3mm
Surface Area of Cone (Sd)9cm²
Cone MaterialPoly Composite
Surround MaterialSantoprene®
Magnet MaterialNeodymium
Overall Outside Diameter1.81"
Baffle Cutout Diameter1.67"
Depth0.61"
Vented Volume0.01ft³
Vented F3112.4Hz
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
