  • Tang Band T2-2136SF Full Range Speaker Module 2-3/4" x 2-3/4"
Tang Band
Part #264-938
Tang Band
Part #264-938
Model: T2-2136SF
Tang Band's T2-2136SF features a passive radiator-assisted 57 mm aluminum cone driver that plays from 80 to 20,000 Hz in a tiny 2.75" square package. Easily design ultra compact modern speakers never before thought possible.
  • 57 mm aluminum cone driver with rubber damping and surround
  • Rear-mounted passive radiator extends system response to 80 Hz
  • Compact 2.75" square self-contained design, no additional enclosure needed
  • Just add an amplifier for high-quality, full-range sound!
Your Price: $54.98
MSRP: $70.99
Save $16.01 (23%)
Quantity:Qty: 1-3 $54.98/ea
Quantity:Qty: 4+$52.23/ea
Tang Band's line of patented speaker modules are designed for modern audio applications such as sound bars, desktop multimedia speakers, flat panel TV speakers, and portable audio systems. Don't let Tang Band's diminutive driver modules fool you; each is built with a passive radiator that extends midbass frequency response, allowing these to mate to a subwoofer system quite easily.
The T2-2136SF speaker module is built around a passive radiator assisted, aluminum cone 57 mm inverted dome driver. This allows for a very full frequency response from a single, small driver. Advantages of this type of speaker design include the elimination of crossover components in the critical midrange, superb off-axis response due to the use of a small driver (without hot spots), and perfect time-alignment.
Note: Tang Band recommends the use of a 2nd order (-12 dB/octave) 60 Hz minimum high pass filter for the best possible sound. Higher power handling and output is possible by deploying multiple modules together.
BrandTang Band
ModelT2-2136SF
Part Number264-938
UPC848864039275
Weight0.4
Nominal Diameter2"
Power Handling (RMS)10 Watts
Power Handling (MAX)20 Watts
Frequency Response80 to 20,000Hz
Sensitivity80dB 2.83V/1m
Voice Coil Diameter1"
Cone MaterialAluminum
Overall Outside DiameterSquare: 2.75"
Baffle Cutout Diameter2.25"
Depth2.23"
