  • Talent K9-TX4 4 Channel Cat5 XLR Audio Snake Box
Talent Sound & Lighting
Part #183-4020
Model: K9-TX4
Consolidate your wire and make cable clutter a thing of the past. The Talent K9-TX4 allows you to send XLR, AES/EBU, or DMX signals through a single CAT5 or greater cable up to 325 feet.
  • Keep your cables tidy and organized by reducing the number of cables used
  • Connect up to 4 XLR cables for maximum convenience
  • Easily connect an Ethercon CAT5 or greater cable for maximum durability
  • Perfect for easy setup and tear down on stage
  • Able to send a signal up to 325 feet for ultimate flexibility
Your Price: $34.98
MSRP: $47.99
Save $13.01 (27%)
Quantity:Qty: 1-3 $34.98/ea
Quantity:Qty: 4+$31.48/ea
Order in the next 1 hr 0 min to ship today. Details
Ditch the old cable snake and upgrade with Talent!
The Talent K9 Series of XLR extenders is a modular system that allows you to consolidate up to four XLR channels into a single CAT5 ethernet cable. This saves money and reduces clutter, allowing you to run cables more efficiently and quickly set up your show. The K9 Series is compatible with digital and analog signals, as well as DMX lighting control signals.
Durable Design
High-strength steel construction makes the K9 series a reliable tour-grade product
Quality XLR Connectors
High-quality XLR connectors on every model
CAT5 Outputs
Robust CAT5 connector provides durability and prevents accidental disconnections
All you need
The Talent K9 TX4 is the perfect solution for any situation where you need to extend the signal from one location to another with minimal cabling. With four XLR inputs and one CAT5 cable output, you can connect up to four channels of audio to the K9-TX4 from any gear with a 3-Pin XLR input.
The convenient modular design allows you to connect multiple K9 extenders together without having to worry about running extra cables or having them get in the way. With its high-quality construction and gold-plated connectors, you can rest assured that the K9 RX4 will provide reliable performance every time.
All you want
The Talent K9 CAT5 Extenders give you confidence in the connections you need to put on a show. Send and receive signals with minimal loss through high-quality XLR, TRS, and ethercon-type connectors. Carry the convenience to and from the stage through easily manageable and affordable CAT5 cables!
The K9 Series consists of 3-Pin Male and Female XLR boxes and pigtails, and a 1/4" TRS box for any situation you can think of whether you're using analog audio, digital audio, or even DMX lighting control signal!
Shop The Whole K9 Series by Talent
Expand on top of the K9 TX4 with the rest of the Talent K9 CAT5-XLR Extenders to create a customized distribution network.
Talent K9-RX4
4 Male XLR Ports
1 CAT5 Output
Shop Now
Talent K9-Mini RX
4 Male XLR Cables
1 CAT5 Output
Shop Now
Talent K9-Mini TX
4 Female XLR Cables
1 CAT5 Output
Shop Now
Talent K9-Mini TRS
4 1/4" TRS Connectors
1 CAT5 Output
Shop Now
BrandTalent Sound & Lighting
ModelK9-TX4
Part Number183-4020
UPC848864070186
Weight1.1
