Talent K9-Mini TRS Cat 5 Audio Snake
Ditch the old cable snake and upgrade with Talent!
The Talent K9 Series of extenders is a modular system that allows you to consolidate up to four channels into a single CAT5 ethernet cable. This saves money and reduces clutter, allowing you to run cables more efficiently and quickly set up your show. The K9 Series is compatible with digital and analog signals, as well as DMX lighting control signals.
Durable Design
High-strength steel construction makes the K9 series a reliable tour-grade product
Quality TRS Connectors
High-quality XLR connectors on every model
CAT5 Outputs
Robust CAT5 connector provides durability and prevents accidental disconnections
All you need
The Talent K9-mini TRS is the perfect solution for any situation where you need to extend the signal from one location to another with minimal cabling. With four TRS cables and one CAT5 cable output, you can connect up to four channels of balanced audio to the K9-mini TRS.
The convenient modular design allows you to connect multiple K9 extenders together without having to worry about running extra cables or having them get in the way. With its high-quality construction and gold-plated connectors, you can rest assured that the K9-Mini TRS will provide reliable performance every time.
All you want
The Talent K9 CAT5 Extenders give you confidence in the connections you need to put on a show. Send and receive signals with minimal loss through high-quality XLR, TRS, and ethercon-type connectors. Carry the convenience to and from the stage through easily manageable and affordable CAT5 cables!
The K9 Series consists of 3-Pin Male and Female XLR boxes and pigtails, and a 1/4" TRS box for any situation you can think of whether you're using analog audio, digital audio, or even DMX lighting control signal!
Shop The Whole K9 Series by Talent
Expand on top of the K9-Mini TX with the rest of the Talent K9 CAT5-XLR Extenders to create a customized distribution network.
