  • Talent USB Microphone With Free Vocal Booth, Shock Mount, Pop Filter
CLEARANCE Talent USB Microphone With Free Vocal Booth, Shock Mount, Pop Filter
Talent Sound & Lighting
Part #233-090
Model: HRS1
With the All-In-One Podcast recording bundle from Talent, anyone can really be a Podcaster without leaving the comfort of home! You get a high quality, plug and play USB microphone with a shock mount and pop filter, as well as a portable isolation booth to make sure your recordings sound just like the pros!
  • High quality USB mic, isolation booth, shock mount, and pop filter ensure a clean, professional recording
  • Attaches easily to any 5/8"-27 TPI microphone stand
  • All for less than the price of one typical USB mic
  • Easily add a mic stand and your favorite recording software for everything you need to get started
CLEARANCE $24.99
MSRP: $199.99
Save $175.00 (88%)
348In Stock
The new All-In-One Podcast recording package from Talent Sound & Lighting gives you an awful lot of oomph, at a price you won't believe. You get a mini vocal booth, USB mic with cable, shock mount, pop filter, even a mini tripod stand for desktop use -- all for under 100 bucks?! Yes. All for under 100 bucks!
The USB-1 microphone offers a super-simple plug and play solution to recording at home (or on the go with your laptop), and it sounds frickin' awesome! No expensive preamps and/or interfaces to buy or hassle with. No drivers to install or be vexed by. Just plug it in to an open USB port, and BAM! You're ready to record in your favorite DAW or recording software. A tight cardioid polar pattern keeps the recording focused on your voice or instrument, rejecting ambient noise.
YouTubers, podcasters, vloggers, home recording buffs, and others will appreciate the attention to detail, quality, and simplicity of this package. The VB-1 mini portable vocal booth is already one of Talent's top-selling items, so adding a great sounding USB mic, pop filter, and more goodies makes it a no-brainer for anyone interested in computer-based recording or audio production of any kind.
Isolation Booth Specifications: • Overall dimensions: 19-1/4" (fully opened) to 5" (closed) wide, 12" high, 10" (closed) to 3-1/2" (fully opened) deep • Threads: 5/8"-27 TPI • Adapter dimensions: 5-7/8" long, 5-1/4" high • Adapter adjustable depth range: 1" to 5".
Pop Filter Specifications: • Overall diameter: 6" • Gooseneck length: 11-1/2"
Microphone Specifications: • Element: 14 mm back electret condenser • Polar pattern: cardioid • Frequency response: 20 - 17,000 Hz • Sensitivity: -34 dB ± 2 dB (0 dB = 1v/Pa at 1 kHz) • Output impedance: 1000 ohms • Load impedance: 100 ohms (at 1 kHz) • Equivalent noise level: 16 dBA • Max. SPL: 132 dB (at 1 kHz, 1% THD) • S/N ratio: 78 dB • Works with Windows 2000/XP/Vista/7/8/10/Mac OS systems without installing driver.
NOTE: The All-In-One bundle does not include any software; however, many great software recording solutions are available for little or no cost online. We recommend Audacity as a free, easy, and effective recording program.
NOTE: The mini tripod stand included with this bundle is designed to support the USB mic only. It is not designed to support the isolation booth. A full-size microphone stand is not included; we recommend our Talent SQMS1 (part number 233-014).
BrandTalent Sound & Lighting
ModelHRS1
Part Number233-090
UPC848864029993
Weight7
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
