  • Switchcraft 3502A RCA Plug Connector Nickel
Switchcraft
Part #093-148
Switchcraft
Part #093-148
Model: 3502APKG
Switchcraft's 3502APKG RCA cable mount plugs have a nickel body with 2 nickel connectors. A solder cup is located on center conductor for fast, easy termination.
  • Solder cup on center conductor for fast, easy termination
  • Solid center conductor
  • High quality appearance
  • Larger cable clamp provides better strain relief for larger cables
  • Longer cable clamp for easier plug assembly and more room for solder connection
  • Knurl on the back of handle provides ergonomic gripping surface to tighten plug
  • Longer handle for improved gripping surface and easy plug withdrawal from jack
Your Price: $2.98
MSRP: $6.23
Save $3.25 (52%)
Quantity:Qty: 1-99 $2.98/ea
Quantity:Qty: 100-249 $2.83/ea
Quantity:Qty: 250+$2.74/ea
360In Stock
Switchcraft's 3502A RCA cable mount plugs have a nickel body with 2 nickel connectors. A solder cup is located on center conductor for fast, easy termination. Larger cable clamp provides better strain relief for larger cables. Heavy duty cable clamp and removable handle accepts cables up to .203" (5.16 mm) diameter. Features include solid pin, shielded handle, and large cable clamp. Terminals may be crimped with pliers for temporary connections or soldered for permanent connections. Plug accommodates multiple jacks spaced on .438" (11.13 mm) centers. Switchcraft phono jacks and plugs are recommended for semi-permanent connections in audio and electronic applications. Mfg. #3502A.
Specifications: • Shell: nickel • Contact plating: nickel • Sold per: each • Finish: nickel • Termination style: solder • Entry hole: 5.6 mm • Dimensions: 0.37" x 1.20"
BrandSwitchcraft
Model3502APKG
Part Number093-148
UPC844632071751
Weight0.025
GenderMale / Plug
Mounting TypeCable Mount
