  • Switchcraft 280 1/4" Mono Plug Nickel
Switchcraft
Part #093-140
Switchcraft
Part #093-140
Model: 280PKG
Switchcraft's 1/4" mono plug features a heavy duty nickel-plated copper alloy handle, tip, and body for unsurpassed ruggedness.
  • Tin electroplated solder terminals
  • Heavy duty cable clamp
  • 7.3 mm cable entry
  • Heat resistant insulator prevents solder issues
Your Price: $3.98
MSRP: $10.97
Save $6.99 (64%)
Quantity:Qty: 1-99 $3.98/ea
Quantity:Qty: 100-249 $3.78/ea
Quantity:Qty: 250+$3.66/ea
463In Stock
Switchcraft's 1/4" mono plug features a heavy duty nickel-plated copper alloy handle, tip, and body for unsurpassed ruggedness. Solder terminals are tin electroplated for ease of soldering. Bright nickel plating on exterior surfaces will not chip or corrode. One-piece tip rod staked into tip terminal ensures electrical continuity. Heavy duty cable clamp provides secure strain relief. Shielded handle versions recommended for applications where electromagnetic interference and physical abuse may occur. Mfg. #280. Specifications: • Terminals: Solder lug - Tinned copper alloy • Sleeve, Tip, and Body: Nickel-plated copper alloy
BrandSwitchcraft
Model280PKG
Part Number093-140
UPC844632091599
Weight0.1
ConductorsMono TS
GenderMale / Plug
Mounting TypeCable Mount
