Part #260-972
Part #260-972
This kit will repair the foam surrounds found on popular AR-3 speaker systems from Acoustic Research. The surrounds in this kit are exact replacements for 11" Acoustic Research woofer, so your AR-3 system will sound as good as it did when it was new from the factory.
Speaker Surround Re-Foam Repair Kit For 11" AR AR-3 / AR-3a Woofer
This kit will repair the foam surrounds found on popular AR-3 speaker systems from Acoustic Research. The surrounds in this kit are exact replacements for 11" Acoustic Research woofer, so your AR-3 system will sound as good as it did when it was new from the factory. This refoam kit contains supplies to repair two speakers and includes two foam surrounds, plastic shims, two dust caps, 1 oz. of adhesive, five foam swabs for application of glue, and complete repair instructions.
Specifications: • Foam outside diameter: 10-3/8" • Foam inside diameter: 7-7/8" • Foam outer edge width: 1/4" • Foam inner edge width: 3/8" • Dustcaps: 2-3/4".
Note: This speaker surround repair kit is not designed for use with subwoofers.
Product Details | |
Brand | Parts Express |
Part Number | 260-972 |
UPC | 844632043451 |
Unit of Measure | Kits |
Weight | 0.84 |
