Do you have an old pair of Cerwin Vegas speakers in the basement with rotten surrounds? Repair them with these new surround kits from Parts Express! The surrounds in these kits are exact replacements for each particular size, so your Cerwin Vega driver will perform as it did when it was new from the factory. Each kit contains supplies to repair two speakers and includes red foam surrounds, plastic shims, two dust caps, 1 oz. of adhesive (specially formulated for various speaker cone materials), five foam swabs for application of glue, and complete repair instructions. A utility knife and isopropyl alcohol are recommended to remove old surround material, but are NOT included in this kit.
Specifications: • Foam outside diameter: 9-3/4" • Foam inside diameter: 7" • Foam outer edge width: 3/8" • Foam inner edge width: 1/4" • Dustcaps: 2-3/4" and 3-3/4".
Note: This speaker surround repair kit is not designed for use with subwoofers.
Product Details | |
Brand | Parts Express |
Part Number | 260-968 |
UPC | 844632043413 |
Unit of Measure | Kits |
Weight | 0.818 |
