  • Stahl Tools DSDS Variable Temperature Digital Solder and Desolder Station
Stahl Tools
Part #374-400
Stahl Tools
Part #374-400
Model: DSDS
You can achieve professional results for even the most sensitive components with the Stahl Tools DSDS digital temperature controlled soldering/desoldering station. The all-in-one design enables you to quickly remove and install electrical components and wires in PC boards, saving work space and power.
  • Complete soldering/desoldering station for production and service use
  • Temperature range from 320°F to 896°F for versatility
  • Independent 2-1/4" x 1-1/8" displays show desired and actual temperature settings
  • Soldering iron and desoldering gun go into sleep mode after 15 minutes of non-use saving power and element wear
  • Soldering iron and desoldering gun operate together or independently to save time and electricity
  • Super-slim ESD safe pencil soldering iron with long lasting PTC heating element and internal temperature probe
  • Includes base, holders, cleaning sponge, extra desoldering tips, extra filters, and cleaning tool for desoldering gun
Your Price: $199.98
MSRP: $279.99
Save $80.01 (29%)
Order in the next 9 hr 26 min to ship today. Details
One Soldering Station for Multiple Jobs
Why have several different soldering irons, guns, and stations to solder and desolder various jobs when you only need the Stahl Tools DSDS variable temperature digital soldering/desoldering station? Whether you're soldering heavy wires together or small components into a PC board, each tool heats up quickly from 320° to 896° F to meet multiple temperatures for a production quality job. If you need to quickly remove a component from a PC board without leaving any solder behind, just switch to the desoldering gun, set to the desired temperature, and with one squeeze of the trigger (after the solder melts) vacuum up all the solder and remove the component. So, why take up several AC outlets, wait several minutes for irons to warm up, and forget to unplug them, when one space and power saving soldering/desoldering station is all you need?
Power Saving Automatic Sleep Mode and Separate Power Switches
Each tool has sleep mode which cools the heating element down to the minimum temperature after 15 minutes of non-use to save power and to increase its longevity. Simply pick up the tool out of its holder and it quickly returns to the desired temperature. Turn the tool completely off by using its individual power switch to save even more electricity.
Super-Slim ESD Safe PTC Pencil Soldering Iron
This ESD (Electrostatic Discharge) safe soldering iron helps keep static away from sensitive electronic components. The specially made plastic handle transfers any static from your hand to ground. The 60W soldering iron has a ceramic PTC (Positive Temperature Coefficient) heating element with an internal temperature probe that aids in temperature consistency. The PTC material also helps extend the life of the heating element. An optional variety tip package (374-401) and replacement soldering iron (374-402) are available.
Electrical Vacuum Desoldering Gun
The 80 watt desoldering gun uses a powered vacuum to suck up solder faster and more efficiently than manual solder suckers. Two filters absorb the solder, preventing it from reaching the electric motor. The gun includes four extra filters, two extra tips, and three cleaning tools. An optional variety tip package(374-403), replacement filters (374-406) and desoldering gun (374-404) are available.
Specifications: • Voltage input: 110~130 VAC 60 Hz • Maximum current draw: 160W • Soldering iron: 60W • Desoldering gun: 80W • Soldering iron and desoldering gun cord length: 43" • AC cord length: 4-1/2 ft. • Replaceable fuse: 3.15A fast blow.
BrandStahl Tools
ModelDSDS
Part Number374-400
UPC848864046396
Weight12.1
