  • JBL Selenium D202Ti 1" Titanium Horn Driver 1-3/8"-18 TPI
Selenium
Part #264-455
Selenium
Part #264-455
Model: D202Ti
With its strong, smooth frequency response, hi-fi sonic signature, and low cost, the new D202Ti-8R high frequency horn driver is on its way to becoming Selenium's most popular transducer ever.
  • Ultra-thin yet strong titanium diaphragm yields great overall performance
  • FEA-optimized ferrite magnet for extended response and high efficiency
  • CCAW voice coil on advanced polyimide former
  • Injected plastic phase plug eliminates phase cancellations
  • Precisely engineered diaphragm and alignment mechanism for easy field replacement
  • For use with industry standard 1-3/8"-18 TPI horns
Your Price: $59.99
MSRP: $89.99
Save $30.00 (33%)
Estimated back in stock 3/28/2025
Alert Me When Available
The JBL Selenium D202Ti-8R high frequency horn driver utilizes a strong, low-mass, pure titanium diaphragm to help it deliver impressive results in PA speaker systems, stage monitors, and more. Horn mounting is easy, thanks to the driver's 1-3/8"-18 TPI screw-on threads, and the usefully low minimum crossover point of 1,500 Hz offers plenty of 2-way and 3-way design options.
The D202Ti-8R has an overall sound character that is crisp yet balanced, with a frequency response that is remarkably devoid of drastic peaks or nulls. Other features include a precision-injected plastic phase plug to eliminate phase cancellations, an efficient copper clad aluminum wire voice coil, and a magnet structure optimized by extensive finite element analysis.
In the unlikely event of driver failure, the D202Ti-8R's auto-centering diaphragm assembly facilitates quick and simple replacement.
Specifications: • Power handling: 40 watts (w/xover, 1,500 Hz, 12 dB/octave) • VCdia: 1.7" • Impedance: 8 ohms • Frequency response: 1,000-20,000 Hz (no crossover) • SPL: 106 dB 2.83V/1m • Magnet weight: 7.5 oz. • Dimensions: Overall diameter: 3.54", Depth: 2.44" (including threaded neck) • Weight: 1.96 lbs • Replacement diaphragm available in the Related Items section.
BrandSelenium
ModelD202Ti
Part Number264-455
Weight2.05
Diaphragm MaterialTitanium
Exit Diameter1"
Mounting Type1-3/8"-18 TPI
Power Handling (RMS)40 Watts
