  • Rolls RM67 Rack Mount Mic/Line Mixer 3 XLR/4 RCA 1U
Rolls
Part #245-1154
Rolls
Part #245-1154
Model: RM67
The RM67 is a single rack space mixer designed for the installer/contractor market. The unit mixes three balanced microphones with four stereo sources to mono or stereo balanced outputs.
  • Three microphone inputs w/phantom power
  • Four RCA source inputs
  • Independent tone control for each mic input
  • Automatic paging
  • Remote volume capable
Your Price: $269.00
MSRP: $339.00
Save $70.00 (21%)
Order in the next 11 hr 47 min to ship today. Details
The XLR microphone inputs on the RM67 have mic/line level switches, a send/return insert jack, and individually switchable +12 VDC phantom power. Priority talkover, with variable duck sensitivity is available on one microphone for paging, and on one source input for use with a jukebox, telephone system, etc. Each microphone input has a level and tone control, and each source input has a level control. Bass and treble control is provided for all the sources, and a master output level control adjusts the level of all mixed signals. Source one has an added front-panel 3.5mm input. A pre-master RCA output has been provided for recording, and a remote volume output jack is provided for connection to a 100K ohm linear taper potentiometer for use as an external master level control. AC power adapter included. Made in the USA.
For more than two decades, those in the know have turned to Rolls for the highest quality, reliability, and value. Rolls is an innovative company specializing in domestically manufactured signal interface accessories, mixers, amplifiers, and processors for the audio professional.
Specifications: • Input impedance: 600 ohms balanced; 22k ohms unbalanced • Signal-to-noise ratio: 96 dB • THD: <0.025% • Dimensions: 19" x 1.75" x 6" (48.3 x 4.5 x 15 cm) • Weight: 5 lbs. (2.3 kg).
BrandRolls
ModelRM67
Part Number245-1154
UPC675889006728
Weight5.5
Mixer TypeAnalog
XLR Mic Inputs< 6
