  • RCA VH226E Antenna Rotator with Remote
CLEARANCE RCA VH226E Antenna Rotator with Remote
RCA
Part #210-357
RCA
Part #210-357
The VH226E is an easy-to-use TV antenna rotor that allows the user to change the direction of their TV antenna from inside their home. The simple digital display is easy enough for even the least tech-savvy folks to use.
  • Automatic antenna positioning with programmable memory for easily switchable positions
  • Infrared remote control for fine tuning your outdoor antenna
  • Onboard digital display for easy operation
This programmable antenna rotator with remote allows you to fine tune your outdoor antenna easily from inside. The rotator features automatic antenna positioning which saves your preferred setting for easy attenuation. The digital display allows for easy operation of the unit.
Specifications: • Connection type: 3-wire • Input voltage: 120V • Dimensions: 11.7 x 7.4 x 8.3 inches.
BrandRCA
ModelVH226E
Part Number210-357
UPC044476124341
Weight8
