  • 1M Ohm Audio Taper Rotary Potentiometer 6mm Shaft with Switch - Taiwan
CLEARANCE 1M Ohm Audio Taper Rotary Potentiometer 6mm Shaft with Switch - Taiwan
Parts ExpressPart # 023-212
This one megohm mono potentiometer could be just the thing for your latest project. It includes a SPST switch for on/off applications, like many vintage amplifiers, where the volume knob is also the power switch. Regardless of what you're putting it in, this quality pot from Taiwan won't let you down.
CLEARANCE $2.24
MSRP: $4.99
Save $2.75 (55%)
28 In Stock
We'll send you an email when 1M Ohm Audio Taper Rotary Potentiometer 6mm Shaft with Switch - Taiwan is back in stock or available for preorder.
Maybe you're repairing, restoring, or hot rodding an existing guitar, amplifier, or other electronic equipment. Perhaps you're devising your own unique musical or audio gear from scratch, working on classic vintage receivers, radios, or TV sets. Any way you slice it, Parts Express has the quality components you need to finish the job right, at prices you can afford.
Part Number023-212
UPC848864029771
Electrical CharacteristicsLogarithmic / Audio Taper
Value1M
