  • Quick Lever Wire Nut Splice Inline Wire Connectors with Mounting Tab (2 In 2 Out) 10-Pack
NEW Quick Lever Wire Nut Splice Inline Wire Connectors with Mounting Tab (2 In 2 Out) 10-Pack
Part #095-098
Part #095-098
Use quick lever wire connectors for temporary or permanent connections without having to crimp or solder wires together. They work perfect for fine tuning speaker crossovers and extending speaker/power wires. Splice 28 to 12 AWG wires together.
  • Quickly splice 28 to 12 AWG wires together for permanent or temporary installations
  • Mounting tabs secure non-suspended connections
  • Two inputs and two outputs for extending power and speaker wires
  • Strip 3/8" (9 mm) of insulator from the wire for the most secure connection
  • Handles up to 32A of current
NEW $5.98
MSRP: $6.99
Save $1.01 (14%)
Quantity:Qty: 1-9 $5.98/ea
Quantity:Qty: 10+$5.38/ea
Order in the next 19 hr 53 min to ship today. Details
Connecting Wires Made Easy
Quick lever wire connectors are an excellent solution for anyone looking to simplify the process of making wire connections, whether for temporary or permanent applications. By eliminating the need for crimping or soldering, these connectors allow for quick and efficient electrical connections that can save time and reduce frustration.
Speaker Crossover Development
One of the most advantageous applications of quick lever wire connectors is in fine-tuning speaker crossovers. Calculating the right component values using charts and formulas is great, but when the speaker is assembled the sound isn't quite what you expected. With these quick lever splice connectors your able to quickly try different configurations to achieve the best sound quality. These connectors provide the flexibility to easily change capacitors, resistors, and coils without the hassle of traditional methods until you attain the sound reproduction you're listening for.
Car Audio and More
With a simple lever mechanism, you can securely connect or disconnect wires, making adjustments a breeze. This is especially useful in cramped space car audio installations. The ability to quickly hookup wires in the dash to see which wires go to each speaker saves a lot of time and effort. Strip each wire and simply insert them into the connectors hole and snap the lever down on the wires. If the connection isn't right, lift the lever and pull the wire out. It's that easy.
Don’t hesitate to incorporate quick lever wire connectors into your projects—whether you’re a seasoned professional or a DIY enthusiast. Their user-friendly design and reliability will empower you to make the most of your wiring tasks, ultimately improving both the quality of your work and the enjoyment of your audio experience. Get started today and discover how much time and headaches your able to save!
Part Number095-098
UPC848864079158
Connector TypeButt Splice
