  • Quam SYSTEM 12URS 24" x 24" Lay-In Ceiling Tile Speaker
1 Question, 2 Answers or
Quam
Part #244-3145
Quam
Part #244-3145
Model: SYSTEM 12URS
The SYSTEM 12 by Quam is a complete loudspeaker assembly with a full range loudspeaker, perforated steel baffle, and integral molded fiber enclosure. Finish is a white baked epoxy hybrid. Intended use in an indoor environment, mounted parallel to floor plane in a 24" wide suspended ceiling tile grid for signal tones, voice, and music. The Quam SYSTEM 12 is UL Listed 1480- (UEAY, UAEY7-Canada) when installed in accordance with supplied installation instructions, requirements of NEC and AHJ. Made in Chicago, USA.
  • 24" x 24" lay-in speaker tile
  • 4W, 25/70V, rotary select transformer with 5 taps
  • For indoor environments
  • Program material: Signal tones, voice, and music
  • Made in Chicago, USA
Your Price: $109.90
MSRP: $141.54
Save $31.64 (22%)
The SYSTEM 12URS includes all components in a pre-assembled package designed for quick installation. It is a 2? x 2?, lay-in ceiling tile replacement enclosure with a high durability, powder coated and perforated steel baffle, and a lightweight speaker assembly that includes an 8?, high efficiency speaker with a 5 oz. magnet and a 4 Watt, 25/70V transformer with rotary tap selector.
By providing high intelligibility, visual appeal and excellent reliability, the SYSTEM 12URS is designed for a wide range of commercial sound applications. The SYSTEM 12URS is UL Listed, and provides four (4) seismic tie-off points to comply with local codes in most jurisdictions. The SYSTEM 12URS can be installed in a ceiling tile grid in about one minute, which saves installation labor and enhances your profits. When you need a high quality, great sounding speaker that installs in minutes, make Quam your choice for speakers.
Specifications: • 4W, 25/70V, rotary select with 5 taps (0.25W, 0.50W, 1W, 2W, 4W) • Average sensitivity: 92 dB 1W/1m • Power rating: 12 watts RMS • Max. system output: 98 dB, 5W/1m • Magnet type: weight: BeFe ceramic, 5 oz. nominal • Frequency response: 65 Hz - 17 kHz • Nominal coverage angle: 100° included angle, -6 dB/ 2 kHz, half space • Audio connection: 7-1/2" long labeled, tinned wires, pre-cut.
BrandQuam
ModelSYSTEM 12URS
Part Number244-3145
UPC851564007178
Weight7
