QSC K8.2 K Series 2-Way 8" Active Loudspeaker 2000WThe QSC K8.2 K Series 2-Way 8" Active Loudspeaker redefines the standard for portable PA systems, offering unparalleled audio performance and versatility. As part of QSC's renowned K.2 series, this compact yet powerful loudspeaker delivers extraordinary sound quality and reliable performance in any setting. Whether for live music, public address, or DJ sets, the K8.2 provides exceptional clarity, detailed sound, and robust output, all housed in a rugged, tour-grade enclosure. Its advanced design and technology make it an ideal choice for professionals seeking a portable solution without sacrificing sound quality.
At the heart of the K8.2's exceptional sound is an 8" woofer paired with a 1.4" titanium compression driver, delivering crisp, detailed highs and rich, deep lows. This two-way active loudspeaker is engineered to provide balanced and powerful sound across a wide frequency spectrum, ensuring your audience experiences every nuance of the performance.
Powered by a 2000 Watt Class-D amplifier, the K8.2 offers ample headroom for any application, from intimate acoustic sets to full-band live performances. This high-efficiency amplifier not only delivers powerful output but also ensures the reliability and longevity of the loudspeaker, even under demanding conditions.
The advanced onboard DSP extends the K8.2's versatility, with user-selectable presets for various applications (e.g., DJ, live band, vocal PA) and Intrinsic Correction™ tuning technology. These features allow for precise control over the sound, ensuring optimal performance in any environment.
Adaptability is key with the K8.2. Whether pole-mounted for a mobile DJ setup, wall-mounted in a venue, flown for a live event, or used as a floor monitor for onstage performance, this loudspeaker offers unparalleled installation flexibility. Its dual angle design also allows for more efficient coverage when used as a stage monitor.
Designed with the professional in mind, the K8.2 boasts a rugged ABS enclosure that's both durable and lightweight. This ensures the loudspeaker can endure the bumps and bruises of touring, making it a reliable companion for traveling musicians and event professionals alike.
Ease of use is paramount in live sound situations, and the K8.2 excels with its intuitive user interface. The rear panel features a digital display and straightforward controls, making setup and adjustments quick and painless, even in the heat of a gig.
- Woofer: 8"
- Compression Driver: 1.4" Titanium
- Frequency Response (-6 dB): 59 Hz - 20 kHz
- Nominal Coverage Angle: 105°
- Maximum Rated SPL: 128 dB @ 1M, peak - 122 dB @ 1M continuous
- Amplifier: Class D, 1,800 W (LF), 225 W (HF)
- AC Power Input: 100-240 VAC, 50-60 Hz
- Enclosure: Impact Resistant ABS
- Attachment Points: 2 x M10 threaded inserts plus Pull-Back
- Dimensions: 449mm × 280mm × 269mm (17.7" × 11" × 10.6")
- Weight: 12.2 kg / 27 lb
