  • QSC K10.2 K Series 2-Way 10" Active Loudspeaker 2000W
NEW QSC K10.2 K Series 2-Way 10" Active Loudspeaker 2000W
QSC Audio
Part #245-702
QSC Audio
Part #245-702
Model: K10.2
The QSC K10.2 K Series 2-Way 10" Active Loudspeaker redefines the standard for portable PA systems, offering unparalleled audio performance and versatility. As part of QSC's renowned K.2 series, this compact yet powerful loudspeaker delivers extraordinary sound quality and reliable performance in any setting.
  • Superior Sound Quality: Features an 10" woofer and a 1.4" titanium compression driver for clear, powerful audio across a broad frequency range.
  • 2000 Watt Class-D Amplifier: Ensures high-performance sound with dynamic headroom and long-term reliability.
  • DSP Technology: Advanced onboard DSP provides extensive audio tuning capabilities, including user-selectable presets for common applications.
  • Versatile Mounting Options: Can be pole-mounted, wall-mounted, flown, or used as a floor monitor, offering flexibility in any setup.
  • Rugged and Portable: Constructed with tough ABS enclosures to withstand the rigors of on-the-road wear and tear while remaining lightweight and easy to transport.
  • Intuitive User Interface: Equipped with a digital display and easy-to-use controls for quick setup and adjustments.
NEW $799.99
MSRP: $999.99
Save $200.00 (20%)
The QSC K10.2 K Series 2-Way 10" Active Loudspeaker redefines the standard for portable PA systems, offering unparalleled audio performance and versatility. As part of QSC's renowned K.2 series, this compact yet powerful loudspeaker delivers extraordinary sound quality and reliable performance in any setting. Whether for live music, public address, or DJ sets, the K10.2 provides exceptional clarity, detailed sound, and robust output, all housed in a rugged, tour-grade enclosure. Its advanced design and technology make it an ideal choice for professionals seeking a portable solution without sacrificing sound quality.
At the heart of the K10.2's exceptional sound is an 10" woofer paired with a 1.4" titanium compression driver, delivering crisp, detailed highs and rich, deep lows. This two-way active loudspeaker is engineered to provide balanced and powerful sound across a wide frequency spectrum, ensuring your audience experiences every nuance of the performance.
Powered by a 2000 Watt Class-D amplifier, the K10.2 offers ample headroom for any application, from intimate acoustic sets to full-band live performances. This high-efficiency amplifier not only delivers powerful output but also ensures the reliability and longevity of the loudspeaker, even under demanding conditions.
The advanced onboard DSP extends the K10.2's versatility, with user-selectable presets for various applications (e.g., DJ, live band, vocal PA) and Intrinsic Correction™ tuning technology. These features allow for precise control over the sound, ensuring optimal performance in any environment.
Adaptability is key with the K10.2. Whether pole-mounted for a mobile DJ setup, wall-mounted in a venue, flown for a live event, or used as a floor monitor for onstage performance, this loudspeaker offers unparalleled installation flexibility. Its dual angle design also allows for more efficient coverage when used as a stage monitor.
Designed with the professional in mind, the K10.2 boasts a rugged ABS enclosure that's both durable and lightweight. This ensures the loudspeaker can endure the bumps and bruises of touring, making it a reliable companion for traveling musicians and event professionals alike.
Ease of use is paramount in live sound situations, and the K10.2 excels with its intuitive user interface. The rear panel features a digital display and straightforward controls, making setup and adjustments quick and painless, even in the heat of a gig.
  • Woofer: 10"
  • Compression Driver: 1.4" Titanium
  • Frequency Response (-6 dB): 56 Hz - 20 kHz
  • Nominal Coverage Angle: 90°
  • Maximum Rated SPL: 130 dB @ 1M, peak - 124 dB @ 1M continuous
  • Amplifier: Class D, 1,800 W (LF), 225 W (HF)
  • AC Power Input: 100-240 VAC, 50-60 Hz
  • Enclosure: Impact Resistant ABS
  • Attachment Points: 2 x M10 threaded inserts plus Pull-Back
  • Dimensions: 519mm × 320mm × 300mm (20.4" × 12.6" × 11.8")
  • Weight: 14.5 kg / 32 lb
BrandQSC Audio
ModelK10.2
Part Number245-702
UPC684284065537
Weight38.8
Speaker TypeActive / Powered
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
