  • QSC GX5 Power Amplifier 500 Watts/ch at 8 ohms
QSC Audio
Part #245-652
QSC Audio
Part #245-652
Model: GX5
The GX5 is ideal for 8 ohm speakers with a 400-600 watt power rating (program) or 4 ohm speakers with a 550-900 watt power rating (program).
  • Power levels matched to the most popular speakers used by entertainers
  • Optimized for maximum real-world headroom into 4 ohm and 8 ohm speaker systems
  • Outputs: Speakon® combo accepts, 1/4" (TS) plugs or Speakon 2-pole and 4-pole plugs
  • Detented gain controls for precise setting and matching of sensitivity
  • GuardRail™ automatically protects the amplifier and loudspeakers from damage
  • Built-in Subwoofer/Satellite crossover
  • Minimum depth chassis (10.1") fits in compact effects racks
Your Price: $599.99
MSRP: $702.19
Save $102.20 (15%)
Out of Stock
QSC designers, headed by Pat Quilter, have optimized output and appearance while reducing raw material cost and weight. GX Series amplifiers are ideal for professional entertainers who require maximum performance and portability on a limited budget. It's all here – dramatic styling, easy hookup and adjustments, excellent audio quality and QSC reliability.
GX Series amplifiers are ideal for professional entertainers who require maximum performance and portability on a limited budget. The hallmarks of the QSC brand - professional audio quality, meticulous engineering, precision manufacturing and long-term reliability - are all intrinsic to GX. Add contemporary styling, multiple input/output options, light weight, and advanced protection circuitry, and the GX Series clearly represents real value - something everyone can use.
GX amplifiers deliver just the right amount of power to the most popular speakers used by entertainers. Typically, loudspeaker manufacturers recommend an amplifier with power output equal to the speaker's Program (Music) Power rating or two times (2 x) the Continuous (RMS) Power rating.
Technical Notes
The GX5 uses a Class H  system, based on key elements of the PL Series, (PLX, PL3, CX, DCA) almost doubling power in the same size and weight. QSC design expertise allows the output devices to shift from low-power to high-power rails in less than a millionth of a second, ensuring that the output power is always right where it needs to be without excess loss.
This amplifier uses premium toroidal power transformers for reliable "mid-weight" performance. A variable-speed fan moves air crosswise through the amplifier, drawing cool air in over the power transformer, through the fan, and then over the heat sink. This keeps the transformer cool and allows a full size heat sink to fit in a down-sized chassis.
As always, GX Series amplifiers are fully protected from the usual hazards of the trade, ensuring stable performance and long life.
GuardRail™
GuardRail protection delivers full peak power while preventing detrimental overloads. During excessive clipping, or extreme overheating, GuardRail reduces gain just enough to preserve the integrity of the music, protect the speakers and keep the audience excited, without unprofessional distortion levels or shutdowns.
Subwoofer/Satellite Crossover
A subwoofer reduces strain on the full-range speaker, allowing it to play louder, or letting a smaller speaker do the same job. The GX Series supports this mode with a Crossover switch that splits the full-range input entering Ch 1, sending 20 Hz -100 Hz to the sub (Ch 1) and 100 Hz - 20 kHz to the top box (Ch 2). The front panel gain controls balance the sub and top box, while GuardRail optimizes peak power into the sub and top individually, for greater musical impact and dynamic range. GuardRail optimizes peak power into the sub and top individually, for greater musical impact and dynamic range.
Specifications: • Power output (EIA 1 kHz, both channels driven): 500 watts RMS x 2 (8 ohms), 700 watts RMS x 2 (4 ohms) • Distortion (typical): <0.02% 8 ohms, <0.05% 4 ohms • S/N ratio: 100 dB • Frequency response: 20 Hz - 20 kHz, +0 dB, -1 dB • Input sensitivity: 1.2V • Input impedance: >20k balanced • Voltage gain: 34.4 dB • Output circuitry: 2-tier Class H • Dimensions: 3.5" (2RU) H x 19" W x 10.1" D • Weight: 28 lbs.
Parts Express is authorized to ship QSC products only within the United States, and will only ship QSC products to addresses located within the USA.
BrandQSC Audio
ModelGX5
Part Number245-652
UPC684284055361
Weight31
Output Channels2
Weight Range30 to 39 lbs.
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
