  • Pyramid PS52KX Rack Mount 12-15V 40A DC Power Supply
CLEARANCE Pyramid PS52KX Rack Mount 12-15V 40A DC Power Supply
Pyramid
Part #120-558
Pyramid
Part #120-558
Model: PS52KX
If you need massive quantities of DC current, this is the power supply for you! Perfect for testing large automotive amplifiers. The built-in fan ensure cool operation even when used at the full rated output for extended periods of time.
If you need massive quantities of DC current, this is the power supply for you! Perfect for testing large automotive amplifiers. The built-in fan ensure cool operation even when used at the full rated output for extended periods of time. Adjustable voltage, dual current/voltage meters, and short circuit/overload protection further increase the value of this supply. Features two sets of high current binding posts. Also features a heavy duty, rack mountable case.
Specifications: • Output voltage: 12-15 V (variable) • Output current: 40 amps (cont), 50 amps (surge) • Ripple voltage: Less than 1mV at rated output • Input voltage: 120 VAC, 60Hz • Weight: 40 lbs.
BrandPyramid
ModelPS52KX
Part Number120-558
UPC068888701716
Weight40
DC Output VoltageVariable
Input Voltage120 VAC
