  • Pyle PMX7BU 3-Channel DJ MP3 Mixer with Bluetooth & USB Flash Drive Reader
CLEARANCE Pyle PMX7BU 3-Channel DJ MP3 Mixer with Bluetooth & USB Flash Drive Reader
Pyle Audio
Part #248-4758
Pyle Audio
Part #248-4758
Model: PMX7BU
The Pyle PMX7BU Bluetooth DJ mixer ensures great performances. Mix your digital library with your turntables or other connected devices, with the added ability to stream music from a Bluetooth enabled device. With the mic talk over ability, your mic will sound crystal clear and cut through the music. Each channel of the mixer has independent volume controls with a crossfader to blend channels.
  • Built-in Bluetooth for wireless music streaming
  • Mix 2 switchable line and phono inputs with Bluetooth audio
  • Mic talk over ability for speaking over audio and karaoke
  • 1/4" headphone jack with volume control
  • Independent 3 channel controls and crossfader
  • USB Flash drive reader
Mix your entire digital library via turntable or other media player with streaming music via Bluetooth. Mix two aux sources, either phono or line level, with Bluetooth audio or MP3s vis the USB flash reader. Preview your mix with the 1/4" headphone jack to ensure your performance is flawless. Independent volume controls for each of the three channels allows you to create the perfect mix and then blend the channels via the crossfader. The talk over mix is perfect for karaoke and for making announcements over music.
Specifications: • Inputs: 2 phono (unbalanced), 2 1/4" TRS (balanced) • Frequency response: 20 - 20,000 Hz • Power consumption: 0.5W max • Dimensions: 5.31" H x 9.25" W x 2.36" D.
BrandPyle Audio
ModelPMX7BU
Part Number248-4758
UPC068888757089
Weight2.6
MONSTER DEAL
OF THE WEEK
$23.98 EACH
SAVE 20%
Lepai LP‑2020BT Bluetooth Hi-Fi Audio Mini Class D Stereo Amplifier FM Media with Power Supply
