  • Powered Dayton Audio Reference 10" Subwoofer Kit with Dual Passive Radiators & 500 Watt DSP Plate Amp
CLEARANCE Powered Dayton Audio Reference 10" Subwoofer Kit with Dual Passive Radiators & 500 Watt DSP Plate Amp
Part #300-7152
Part #300-7152
Model: 300-7152
This subwoofer kit may look modest, but it is capable of some serious output and low frequency extension. Using the Dayton Audio RSS265HO-4 10" driver teamed up with dual RSS265-PR passive radiators you can expect outstanding output along with extremely low distortion. For power we include the SPA500DSP providing 500 watts of power with user programmable DSP which make it easy to seamlessly integrate this subwoofer in almost any system and room.
  • Unobtrusive 13" cube enclosure will fit easily into almost any room
  • Dayton Audio RSS265HO-4 10" driver provides incredible output with low distortion
  • 500 watt amplifier with simple user adjustable DSP for ample power and flexibility
  • Customize the precision CNC-cut MDF enclosure to fit in any decor
This 13" cube subwoofer is small enough for use in smaller rooms, but has the power and extension needed for larger spaces as well. Using Dayton Audio's RSS265HO-4 10" driver teamed up with two of the matching RSS265-PR passive radiators, this subwoofer will provide amazing output capability for its size while producing extremely low distortion. Powering the system is the Dayton Audio SPA500DSP amplifier, delivering 500 watts of power and with simple user adjustable DSP, this amplifier allows the subwoofer system to integrate easily into almost any existing system. In addition, with the added flexibility and adjustment capability of the built in digital signal processing, this subwoofer system allows you to correct the peaks and dips in response that are almost always caused by your listening room.
Dayton Audio RSS265HO-4 10" Subwoofer Specifications: • Power handling: 600 watts RMS/1,200 watts max • Le: 1.74 mH • Impedance: 4 ohms • Re: 3.5 ohms • Frequency response: 24-600 Hz • Fs: 26.9 Hz • SPL: 87.2 dB 2.83V/1m • Vas 1.04 ft³ • Qms: 4.02 • Qes: 0.39 • Qts: 0.35 • Xmax: 12.3 mm.
Dayton Audio SPA500DSP 500W Subwoofer Plate Amplifier Specifications: • Power output: 500 watts RMS into 4 ohms, THD+N <1.0% • Signal to noise ratio: 97.9 dB (A-weighted) • Power requirements: 110~120/220~240 VAC selectable, 50/60 H • Low pass adjustment: 30 Hz to 125 Hz • Phase adjustment: Continuously variable from 0º (normal) to 180º (reverse) • Power requirements: 110~120/220~240 VAC selectable, 50/60 Hz.
Enclosure Specifications: • Panel thickness: 3/4" • Panel material: Medium Density Fiberboard (MDF) • Finished internal cabinet volume: 0.8 cubic feet • External dimensions: 13" H x 13" W x 13" D • Completed subwoofer weight: 38.5 lbs. • Made in the U.S.A.
Note: Mounting screws and feet are not included.
Model300-7152
Part Number300-7152
UPC848791005107
Weight53.3
Cabinet Dimensions (HxWxD)13" x 13" x 13"
Cabinet OptionsUnfinished/Unassembled
ColorUnfinished
ConfigurationSubwoofer
Input RatingPowered
Speaker TypeSubwoofer
Woofer Diameter10"
