  • 3-12V 1.5A Regulated 6-Way DC Power Supply
CLEARANCE 3-12V 1.5A Regulated 6-Way DC Power Supply
Parts ExpressPart # 120-536
This compact sized regulated power multi-voltage power supply is ideal for all devices drawing up to 1.5 amps of current.
  • Small size consumes less space on workbench or desk
  • Variable voltages 3, 4.5, 6, 7.5, 9, and 12 VDC
  • Fits most dual plug banana jacks
  • 1 amp fuse to protect from power input surges
CLEARANCE $32.57
MSRP: $45.99
Save $13.42 (29%)
177 In Stock
We'll send you an email when 3-12V 1.5A Regulated 6-Way DC Power Supply is back in stock or available for preorder.
This compact sized regulated power supply is ideal for all devices drawing up to 1.5 amps of current. It is fully regulated ensuring constant, accurate DC power to any type of electronic device. The rotary selector can switch between six popular voltages (3-4.5-6-7.5-9-12V DC). The color coded binding posts make connections easy. This unit works well with the detachable plug kit 120-537 by supplying an easy termination for the popular DC plugs on the market today.
Note: Use a 1.5A external output fuse to protect sensitive internal circuits.
Specifications: • Dimensions: 2.5" H x 4" W x 5.25" D • Banana Jack hole spacing: 0.71" (18 mm) center to center.
Part Number120-536
UPC844632026492
Weight3.06
DC Output Voltage3V-4.5V-6V-7.5V-9V-12V
Input Voltage120 VAC
