  • Portable 30 Watt Battery Powered Bluetooth Speaker Package with 2-1/2" Full-Range Drivers
Part #300-7300
Part #300-7300
This bundle includes all of the electronics needed to construct your own high-end portable battery powered Bluetooth speaker. We have bundled compatible amplifier, power supply, batteries and driver components together to save you time shopping and nearly $20 off the regular retail price.
  • Includes a Bluetooth amplifier, battery board, batteries, wires, power supply, and drivers
  • Dayton Audio PC68-4 drivers feature smooth response with true full-range reproduction
  • The Dayton Audio KAB-215 amplifier provides 2 x 15 watts and includes Bluetooth
  • Powered by 3 x 2,600 mAh Li-Ion batteries for long lasting run time
Your Price: $99.98
MSRP: $129.99
Save $30.01 (23%)
Parts express has put together all of the electronic components needed to build your own 2 x 15 watt battery powered Bluetooth speaker with stereo 2-1/2" full range drivers. This kit is perfect for building a custom self-contained Bluetooth enabled speaker from the ground up or simply incorporating audio capability into any existing enclosure. Thanks to the convenience, ease of assembly, and great sound this kit is sure to impress!
 Recommended enclosure volume for this package is 0.21 ft³ tuned to 70 Hz using 2 ports that are 1" diameter x 3.25" long.
Included in this package:
Dayton Audio KAB-215v2 2 x 15W Amplifier Board with Bluetooth 5.0
The Dayton Audio KAB-215v2 2 x 15 watt Bluetooth amplifier board delivers high quality sound without drawing a lot power. Its ultra-low distortion and pop-free performance make this hi-fi amplifier board an integral asset in any quality audio build.
2 x Dayton Audio PC68-4 2-1/2" Full-Range Poly Cone Drivers
The Dayton Audio PC68-4 2-1/2" full-range driver features a poly damped woven glass fiber cone, rubber surround, and high energy motor. The Dayton Audio PC68-4 driver will deliver high fidelity and low distortion from compact applications.
Dayton Audio KAB-BE 18650 Battery Extension Board
Lithium battery power is your best option when building high power portable sound projects. Connect and charge three 18650 lithium batteries to your KAB board using the Dayton Audio KAB-BE. Enjoy prolonged listening with this advanced power option.
Dayton Audio KAB-AB L-type Aluminum Bracket
The KAB-AB aluminum bracket makes it easy to securely mount the KAB boards and improve space efficiency . This aluminum bracket supports vertical and horizontal mounting configurations to satisfy different installation requirements.
Note: Crossover components may be substituted with parts of equal or higher quality depending on available inventory.
Model300-7300
Part Number300-7300
UPC848864050751
Weight2.84
Cabinet OptionsWithout Cabinet
ConfigurationFull-range
Input RatingPowered
Speaker TypePortable Bluetooth
Woofer Diameter2.5"
