  • Pocket Size Solar Rechargeable 10W Work Light with 2.1A Output Power Bank
Part #361-681
Part #361-681
Don't buy another power bank that just sits around collecting dust until you need it. This combination solar rechargeable work light power bank charges your smartphone with 2.1A of current, and delivers 400 lumens of hands-free light.
  • Foldout magnetic stand for hands-free operation
  • Dual-brightness LED work light delivers 400 lumens in high mode
  • Recharges by direct sunlight for outdoor events
  • 5 VDC and 2.1A of current output for charging smartphones and tablets
  • Red flashing SOS mode for emergencies
  • Includes micro USB to USB-A charging cable
  • CE and RoHS compliant
Your Price: $21.98
MSRP: $29.99
Save $8.01 (27%)
Why spend over $30 for a 5 VDC 4400 mAh power bank that just sits around for months before you use it? This combination power bank, emergency, and work light is perfect for lighting up automotive engine compartments, attics, crawl spaces, and utility closets. This work light has two modes of brightness, a stand, and two magnets to make sure both hands are free to do repairs. Pull the stand all the way out and this work light turns into a lantern to hang, or to carry. If broke down on the road, press the emergency button, pull the stand out, and set the light on the road behind your vehicle and wait safely in your car until help arrives.
This 2.1A charging power bank keeps smartphones and tablets going when the power goes out, or for outdoor getaways. The power bank fully charges most smartphones and tablets when they are in sleep mode. This makes it great for camping trips, bike rides, and international traveling.
There're two ways to recharge the internal battery in the work light. Find a powered USB port to recharge the battery and its ready to go in 5 to 6 hours, or recharge the work light all day with direct sunlight so it's ready for evening events.
Specifications: • Dimensions: 4.33" W x 3.15" H x 1.29" D • Charging cable: 3 ft. micro USB to USB-A • Charging input jack: Micro USB 5 VDC 0.5 to 2A • Charging output jack: USB-A 5 VDC 2.1A • Battery life per charge: 4400 mAh or 4 to 8 hours depending on light mode • Battery charging time: about 5 hours • Light output high mode: 400 lumens • LED work light color: White 5500-6000K
Part Number361-681
UPC848864062846
Weight0.65
