  • Peerless by Tymphany TC9FD18-08 3-1/2" Full Range Paper Cone Woofer
Part #264-1062
The TC/TG Series from Tymphany offers a high performance full range and mid-bass solution for TV products and other compact applications.
  • Light weight, non-resonant polymer chassis
  • Patented NRSC paper cone
  • Copper pole piece cap controls impedance
  • Frequency response extends past 15 kHz
Your Price: $22.98
489In Stock
The TC/TG Series offers a high performance full range and mid-bass solution for TV products and other compact applications. The use of leading-edge technologies like a polymer chassis, NRSC (Tymphany patent) paper cone, and a copper pole piece cap, have made this full range driver appear on many industry insider lists as the best sounding solution in this market.
BrandPeerless by Tymphany
ModelTC9FD18-08
Part Number264-1062
UPC844632083921
Weight0.7
Nominal Diameter3-1/2"
Bolt Circle Diameter3.5
Power Handling (RMS)30 Watts
Power Handling (MAX)60 Watts
Frequency Response100 to 20,000Hz
Sensitivity83.5dB 2.83V/1m
Voice Coil Diameter0.75"
Resonant Frequency (Fs)125Hz
DC Resistance (Re)6.3Ω
Voice Coil Inductance (Le)0.05mH
Mechanical Q (Qms)2.7
Electromagnetic Q (Qes)1.33
Total Q (Qts)0.89
Compliance Equivalent Volume (Vas)0.04ft³
Mechanical Compliance of Suspension (Cms)0.67mm/N
BL Product (BL)3.01T·m
Diaphragm Mass Inc. Airload (Mms)2.43g
Maximum Linear Excursion (Xmax)2.55mm
Surface Area of Cone (Sd)36.3cm²
Cone MaterialPaper
Overall Outside DiameterDiagonal: 3.62", Across flats: 3.3"
Baffle Cutout Diameter3"
Depth1.69"
Sealed Volume0.08ft³
Sealed F3124.5Hz
Vented Volume0.08ft³
Vented F393.9Hz
