  • Peerless GBS-135F25AL02-04 5-1/4" Aluminum Cone Woofer 4 Ohm
NEW Peerless GBS-135F25AL02-04 5-1/4" Aluminum Cone Woofer 4 Ohm
Peerless by Tymphany
Part #264-1486
Model: GBS-135F25AL02-04
The low profile GBS-135F25AL02-04 from Peerless can deliver high-end performance even when space is at a minimum. With smooth response up to 3,500 Hz and extremely well controlled dispersion, this unique driver can deliver hi-fi sound from the shallowest designs.
  • Just over 1" mounting depth without sacrificing sound quality
  • Amazing excursion capability for powerful bass response from shallow enclosures
  • Optimized ferrite motor design allows impressive efficiency for a low profile driver
  • Excellent choice for car audio systems where space is at a premium
NEW $34.98
MSRP: $47.99
Save $13.01 (27%)
Quantity:Qty: 1-4 $34.98/ea
Quantity:Qty: 5-49 $33.23/ea
Quantity:Qty: 50-99 $31.47/ea
Quantity:Qty: 100-249 $29.72/ea
Quantity:Qty: 250+$27.97/ea
Estimated back in stock 5/2/2025
Alert Me When Available
The Peerless GBS-135F25AL02-04 5-1/4" 4 ohm woofer provides a very slim profile that is capable of large excursion. An anodized aluminum dome helps to extend the piston bands in the working range to deliver flat response from 55 Hz to 3,500 Hz with remarkable off-axis performance. A highly optimized ferrite motor and unique suspension layout combine to give a cost effective solution in a previously unavailable package.
BrandPeerless by Tymphany
ModelGBS-135F25AL02-04
Part Number264-1486
UPC848864044996
Weight2
Nominal Diameter5-1/4"
Bolt Circle Diameter5.59
Power Handling (RMS)35 Watts
Power Handling (MAX)70 Watts
Frequency Response55 to 3,500Hz
Sensitivity88.45dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)63Hz
DC Resistance (Re)3.28Ω
Voice Coil Inductance (Le)0.21mH
Mechanical Q (Qms)4.12
Electromagnetic Q (Qes)0.66
Total Q (Qts)0.57
Compliance Equivalent Volume (Vas)0.189ft³
BL Product (BL)4.92T·m
Diaphragm Mass Inc. Airload (Mms)12.3g
Maximum Linear Excursion (Xmax)3.3mm
Surface Area of Cone (Sd)85.22cm²
Cone MaterialAluminum
Voice Coil FormerAluminum
Overall Outside Diameter6", Across flats: 5.25""
Baffle Cutout Diameter4.68"
Depth1.07"
# Mounting Holes6
Sealed Volume0.2ft³
Sealed F387.8Hz
Vented Volume0.4ft³
Vented F349.7Hz
