  • Peerless by Tymphany BC25SC08-04 1" Silk Dome Neodymium Tweeter with Waveguide 4 Ohm
Part #264-1390
Tymphany's BC25SC08-04 4 ohm 1" silk dome tweeter is surprisingly efficient for its size. With natural response up to 20,000 Hz it is a great choice where space is at a minimum.
  • Powerful neodymium motor increases efficiency and control
  • The silk dome produces a natural, non-fatiguing frequency response
  • Ferrofluid and cooling fins on the motor assembly for increased power handling
  • Waveguide faceplate controls dispersion and increases sensitivity
Your Price: $21.71
MSRP: $24.99
Save $3.28 (13%)
Quantity:Qty: 1-4 $21.71/ea
Quantity:Qty: 5-49 $20.62/ea
Quantity:Qty: 50-249 $19.54/ea
Quantity:Qty: 250+$18.54/ea
Advertised price subject to change due to tariff uncertainty
Alert Me When Available
For its size, the BC25SC08-04 1" silk dome tweeter is an impressive performer. A semi-horn loaded faceplate helps to control dispersion increasing efficiency to 98 dB @ 2.83V/1m. The motor includes a neodymium magnet with ferrofluid and cooling fins allowing the 1" voice coil to handle up to 100 watts of power making this a highly dynamic tweeter. In addition, the smooth frequency response allows for an easy transition to a midrange in higher efficiency compact systems.
BrandPeerless by Tymphany
ModelBC25SC08-04
Part Number264-1390
UPC848864017129
Weight0.18
Cone / Dome Diameter1"
Cutout Diameter1.75
Tweeter TypeSoft Dome
Power Handling (RMS)100 Watts
Sensitivity98.8dB 2.83V/1m
Resonant Frequency (Fs)1660Hz
DC Resistance (Re)2.8Ω
Mechanical Q (Qms)4.9
Electromagnetic Q (Qes)1.53
Total Q (Qts)1.17
Overall Outside Diameter2.75"
Depth1.32"
