  • Peerless by Tymphany 830656 5-1/4" Paper Cone SDS Woofer
Part #264-1078
The Peerless Superior Dynamic Sounds (SDS) Series provides the lowest cost/highest-quality woofers in the industry today.
  • Premium sculpted stamped steel chassis
  • Coated paper cone with rubber edge
  • Smooth, extended response
Your Price: $19.49
MSRP: $25.99
Save $6.50 (25%)
Quantity:Qty: 1-4 $19.49/ea
Quantity:Qty: 5-9 $18.50/ea
Quantity:Qty: 10+$17.55/ea
Advertised price subject to change due to tariff uncertainty
Alert Me When Available
The Peerless Superior Dynamic Sounds (SDS) Series provides the lowest cost/highest-quality woofers in the industry today. The SDS woofers are characterized by their very smooth frequency response all the way into the midrange, with low distortion and consistent off-axis performance. Applying the best in Danish engineering, but manufactured to be very affordable, these audio transducers are ideal for use in small surround sound systems and other hi-fi applications.
BrandPeerless by Tymphany
ModelSDS-P830656
Part Number264-1078
UPC844632084003
Weight1.65
Nominal Diameter5-1/4"
Power Handling (RMS)60 Watts
Power Handling (MAX)110 Watts
Frequency Response50 to 5,000Hz
Sensitivity84.5dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)57Hz
DC Resistance (Re)6.1Ω
Voice Coil Inductance (Le)0.37mH
Mechanical Q (Qms)3.6
Electromagnetic Q (Qes)0.7
Total Q (Qts)0.59
Compliance Equivalent Volume (Vas)0.31ft³
Mechanical Compliance of Suspension (Cms)0.83mm/N
BL Product (BL)5.36T·m
Diaphragm Mass Inc. Airload (Mms)9.3g
Maximum Linear Excursion (Xmax)3.46mm
Surface Area of Cone (Sd)86.6cm²
Cone MaterialCoated Paper
Overall Outside Diameter5.98"
Baffle Cutout Diameter4.61"
Depth2.23"
# Mounting Holes6
Sealed Volume0.3ft³
Sealed F377.4Hz
Vented Volume0.7ft³
Vented F341.9Hz
