  • Peavey PVi 8500 8 Channel 400W Powered Mixer with FX, Bluetooth & SD/USB MP3 Player
CLEARANCE Peavey PVi 8500 8 Channel 400W Powered Mixer with FX, Bluetooth & SD/USB MP3 Player
7 Questions, 8 Answers or
Peavey
Part #248-7941
Peavey
Part #248-7941
Model: PVi 8500
The PVi 8500 has virtually everything a musician needs, including seven combination XLR and 1/4" inputs plus one XLR only input, all using Peavey’s award winning mic preamps, 400 watts of power on tap, a built-in SD/USB MP3 media player, and the ability to link to your favorite mobile devices via Bluetooth.
  • 8-channel, 400 watt powered mixer
  • Digital effects with footswitch on/off control
  • Mid Morph and Kosmos-C for stunning tone & clarity
  • SD card and USB MP3 media player
  • Bluetooth capability for wireless streaming from mobile devices
CLEARANCE $395.00
MSRP: $669.99
Save $274.99 (41%)
1In Stock
The Peavey PVi 8500 is a revolutionary all-in-one powered mixer. It includes everything a musician needs, with 7 combination XLR and 1/4" inputs and one XLR only input, using Peavey's award winning Silencer mic preamps, and 400 watts of power for crystal clear audio reproduction. The PVi 8500 uses exclusive features like Mid Morph EQ to help improve the tone and overall clarity of vocals. Feedback is quickly identified and easily removed with Peavey's 9-band graphic EQ combined with the patented FLS Feedback Locating System. The PVi 6500 is also equipped with Kosmos-C, which drastically enhances both the low and high end of the audio spectrum - exclusive Peavey technology. Footswitchable 24-bit digital effects compliment the feature set by allowing the user to select multiple varieties of reverb and delay. For playback of pre-recorded program material, you have your choice of traditional RCA inputs, 3.5 mm input for smart phones and the like, as well as an on-board SD card or USB thumb drive reader which will play standard MP3 files. The PVi 8500 is also Bluetooth compatible, which means you can pair up to the mobile device of your choice and stream your media with no wires at all! All this in a simple, easy-to-use, and very portable package. What more could you ask for? Peavey item 03601860.
Dimensions: 19.375" x 11.25" x 10.75" • Weight: 22.2 lbs.
BrandPeavey
ModelPVi 8500
Part Number248-7941
UPC014367611281
Weight26.85
Mixer TypeAnalog
XLR Mic Inputs6 to 9
Special FeaturesDigital Effects
MONSTER DEAL
OF THE WEEK
$24.98 EACH
SAVE $5
Lepai LP-2020BT Bluetooth Hi-Fi Audio Mini Class D Stereo Amplifier FM Media with Power Supply
