  • PT2313 DC 12-24V IR Remote Control Tone Preamp board with 3 Aux Inputs
CLEARANCE PT2313 DC 12-24V IR Remote Control Tone Preamp board with 3 Aux Inputs
Part #320-6010
Part #320-6010
Add manual and wireless tone control to an amplifier board with this preamp board with IR remote. It has three AUX inputs for adding Bluetooth, and FM preamp boards plus a 3.5 mm or dual RCA jacks to add versatility to your audio project.
  • Adds extra inputs, plus manual and wireless tone control to amp boards
  • Accepts DC power from 12 to 24 VDC for versatility
  • Blue backlit display for operating status and a professional looking finish
This audio preamp board has multiple features to enhance any audio project. With three selectable line inputs switch between FM radio, Bluetooth, 3.5 mm or RCA jacks. The digital display shows which AUX input you're listening to, along with volume level. Push the treble button on the IR remote and the display temporarily switches to treble volume. Do the same with the bass button. Without the remote press the correct button on the manual control board and it will toggle between bass and treble. The display shows if you're increasing the bass or treble with the volume control knob.
When you press the on/off button for this preamp board it turns off the amplifier board. Hook a DC power cable from your amp's power source into the voltage input on the preamp board. Hook another DC cable to the power output on the preamp board and reconnect the other end to your amplifier board. The relay on the preamp board will disconnect the power from your amp board's power source until you turn the preamp board back on. The preamp board is in standby mode until you turn the power back on. To disable the preamp boards standby mode you must insert an on/off switch into the preamp board's 12 to 24 VDC input.
Specifications: • Voltage input: 12 to 24 VDC • 12 VDC relay: Handles up to 30 VDC @ 3A • Frequency response: 10 Hz-40 kHz • SNR, A-weighted: 95 dB • Channel crosstalk: 62 dB • Bass adjustment: +/- 8 dB @ 85 Hz (bump) • Treble adjustment: +/- 8 dB @ 1 kHz (shelf) • Preout voltages: 2.5V max • Max input sensitivity voltage: 800 mV • Current draw @ 24 VDC: 0.05A • Standby current draw @ 24 VDC: 0.02A Max
Part Number320-6010
UPC848864059976
Weight0.3
Board TypePreamp
Special FeaturesRemote Control-Volume / Tone Control
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
