PRV Audio D4500Ph 2" Phenolic Compression Driver 4-Bolt
- Damped phenolic diaphragm minimizes unwanted peaks for smooth response
- 250 watts RMS and 108 dB efficiency to provide unbelievable output capability
- 450 to 6,000 Hz frequency response to effortlessly cover the majority of the vocal range
- Standard 4 bolt mount to easily install on most 2" throat horns
We'll send you an email when PRV Audio D4500Ph 2" Phenolic Compression Driver 4-Bolt is back in stock or available for preorder.
